Lamp post photocell hook up
Discussion in 'Electrical Forum discussion & Blog' started by mr fix it, Nov 16, 2009.
  1. mr fix it
    mr fix it New Member
    Nov 16, 2009
    New Philadelphia, Ohio
    Hi: Question, I am hooking up a new outside lamp post with photocell dusk to dawn. I will not be hooking it up to electric supply till sometime next spring. Just putting everything together now. I am using conductivity meter to check wiring, everything seems to check out ok except I can not get a conductivity reading acrossed the photocell. I have reading going into cell black wire to black wire but no reading coming out the red wire to light
    I tried covering the cell with black tape and also after dark. Is it possible that conductivity can't be read acrossed a photocell??? Or does the photocell have to be exposed to the light for a day ??? I just took it out of the box. Thanks for any help.
  2. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    Photocells and the like are "electronic circuits" which need to be powered to function.
    And if there are any "diodes" (electronic component) in these electronic circuits, these would need a certain "voltage" (7/10 volt) and a certain "polarity" of voltage to get a reading on a testing device. Some testing devices do not provide this high of a voltage through the test wires.
    In English: Just follow directions, hook it up, and see if it works!
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    A CdS photocell in bright light should read low (~10k?) resistance.
  5. mr fix it
    Nov 16, 2009
    Thanks Billy Bob. That thought did enter my mind. Looks like I will need to power it up to see if it works. many thanks again for the help.
  6. mr fix it
    Nov 16, 2009
    Thanks guy, everyone has been a big help. Nice to have the experts to take your problems too.
  7. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    The PV power from a 3 wire photo cell opens the circuit.
    When you first install and power up a 3 wire photo cell, the light will be on for about 20/30 seconds.
    It seems like you should have continuity between black and red (of the PC) right out of the box
Similar Threads: Lamp post
Electrical Forum discussion & Blog GFCI, Dimmer Switch, Outdoor Lamp Posts with Receptacles Mar 27, 2012
Electrical Forum discussion & Blog Lamp Post Bulb keeps blowing out Aug 30, 2011
Electrical Forum discussion & Blog Replacing lamp post Apr 24, 2010
Electrical Forum discussion & Blog Halogen lamps inquiry Apr 21, 2016
Electrical Forum discussion & Blog Lamp in Middle of Room (Need Power Supply) Apr 19, 2012
