Laminate Flooring on Enclosed Deck
Discussion in 'Remodel Forum & Blog' started by prashster, Dec 28, 2006.
  1. prashster
    prashster New Member
    Dec 7, 2005
    My uncle has a sunroom that is basically an enclosed deck. The floor is slatted deck boards, open to, and elevated from, the ground.
    He wants to put a finished floor on there. What are the best options?
    I suggested a polyethylene barrier over the deck, followed by rigid insulation, then possibly a plywood underlay and finally laminate flooring. Would that work?
    Would cement backerboard be a better choice?
    He received counsel from a flooring guy that laminate is a bad choice in that room because of the climatic changes (it's unheated and uninsulated). But if you can do laminate in a basement, why not in such a room? He'd insulate the floor...
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    A basement is very constant temperature, so there is very little expansion and contraction.
    I would consider some kind of carpet. That is very tolerant of things that would damage laminate or other smooth finish floors.
  4. prashster
    Dec 7, 2005
    Thanks, Bob. What's the best way to insulate the floor?
  5. Bob NH
    Oct 20, 2005
    New Hampshire
    First, figure out how much thickness you can stand.
    Then, I would used a layer of rigid foam, with waterproof facing on the top side or both sides. It needs to have a layer of material that will prevent punching through.
    You can use foam padding under the carpet which will insulate some, if you want that kind of carpet. If you use a more casual carpet without padding, then the foam is the best insulation and you probably need 3/8" of decent plywood for underlayment. I would not rely on 1/4" luan to resist punching a chair leg through to the foam insulation.
Similar Threads: Laminate Flooring
Remodel Forum & Blog Wood Laminate Flooring Over Ceramic Tile Oct 31, 2013
Remodel Forum & Blog Merging Room moldings french door with new laminate flooring types Jun 13, 2011
Remodel Forum & Blog Installing Pergo laminate flooring Feb 17, 2010
Remodel Forum & Blog Wood Laminate Flooring reconsidered Jul 30, 2006
Remodel Forum & Blog Installing laminate flooring in the bathroom Nov 4, 2004
