Laminate Countertop DIY
Discussion in 'Remodel Forum & Blog' started by Lakee911, Jul 26, 2006.
  1. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    To save costs in my kitchen remodel, I would like to take care of the laminate countertop myself. I can order the laminate in fullsize sheets for the countertops. No problem. I've put this down before on small projects and seen it on TV for larger ones (contact cement, carboard strips, roller, etc).
    As for the underlament, a few questions.
    I'm thinking I would use two layers of 3/4" particle board. $12.95 per 4' x 8' sheet at the Orange Box Store. Rough countertop dimensions are as follows
    130" x 25" (<23 sq ft)
    62" x 36" (<16 sq ft)
    42 x 25" (<8 sq ft)
    So, by these calculations I could do it in 3 4x8 sheets! However, I probably don't want a lot of seams in my laminate .... so then I'd be wasting a lot and maybe I could do it in, oh I don't know .... 5 sheets? Better to waste or reuse? Does it matter?
    How do I join the two layers of particle board?
    Do I build the particleboard in place and then glue up the laminate in place and trim? Or do I build it in place, remove it and glue and trim, and reinstall? Or do I attach the laminate to the particleboard and then trim and install the countertop? What's the best way?
    25" depth typical for a 24" base cabinet? What about an island w/ an overhang? 36" deep or 37"?
    Jason V. Advani
    Instrumentation & Controls Engineer
    Red Oak Consulting, a division of Malcolm Pirnie, Inc.
    Direct: 614-430-2654
    Fax: 614-888-6295
Similar Threads: Laminate Countertop
Remodel Forum & Blog Laminate Countertop Replacement May 8, 2012
Remodel Forum & Blog Raw edge of laminate countertop Aug 27, 2005
Remodel Forum & Blog Wood Laminate Flooring Over Ceramic Tile Oct 31, 2013
Remodel Forum & Blog Merging Room moldings french door with new laminate flooring types Jun 13, 2011
Remodel Forum & Blog Installing Pergo laminate flooring Feb 17, 2010
