Laminate counter too deep
Discussion in 'Remodel Forum & Blog' started by frank551, Jan 6, 2006.
  1. frank551
    frank551 New Member
    Jan 6, 2006
    Our laminate counters came in wrong a second time. This time, they are just an inch and a half too deep (front to back). We don't have a backsplash on the counter as most do. What is the best way to rip off that 1.5"? I know to make sure the cut line is taped on the laminate side, but what is the best tool? Table saw, jig saw, router with spiral blade, or a regular old circular saw?
  2. hammerslammer
    hammerslammer New Member
    Dec 10, 2005
    Colorado
    I would cut from the underside with a 24 tooth marathon blade in a skilsaw. I never tape if i'm cuting from the underside but that would be ok. I'm not a countertop guy but I've cut a bunch of them.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Hammerslamer is right as long as you are good with a skill saw. Take your time, go slow, and mark the side you can see with a cut line to follow. Remember "measure twice cut once".
  5. jimbo
    jimbo Plumber
    San Diego, CA
    A jigsaw will tend to make a cut line which varies from perpendicular. A circular saw would be my choice. Cut from the underside. I would mark a cut line, then cut about 1/16" proud of this. Then you can scribe the countertop to the wall, and do final cleanup with a belt sander for a perfect fit.
Similar Threads: Laminate counter
Remodel Forum & Blog Laminate Countertop Replacement May 8, 2012
Remodel Forum & Blog Follow-up: how to remove cast iron sink without damaging laminate counter? Sep 10, 2007
Remodel Forum & Blog Laminate Countertop DIY Jul 26, 2006
Remodel Forum & Blog Raw edge of laminate countertop Aug 27, 2005
Remodel Forum & Blog Wood Laminate Flooring Over Ceramic Tile Oct 31, 2013
