Lake water supply line freeze prevention
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by John Perrie, Sep 10, 2008.
  1. John Perrie
    John Perrie New Member
    Jul 29, 2008
    I am constructing a cottage in Ct. The building is 6" above grade on concrete piers. Water supply is from a lake 40' away. The water line is buried 36" but
    must be exposed above ground at pump connection and were it enters the building. The pump location is designed to be outside against the building in a small enclosure. I know this section will freeze in winter.
    1. Is there a way to insulate and or heat the line to avoid freezing.
    2. Is there a simple way to empty water in pump and line to below freeze depth in soil.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Heat tape!
    What lake are you on?
  4. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    1. Yes
    They make a waterproof heat tape and you can wrap closed cell foam insulation around the pipe and then use a piece of4 inch PVC pipe to protect it.
    2. Not easily.
    Will the cottage freeze in the winter?
    Why not put the pump in the cottage?
    If the system is shut down for the winter, you could use RV antifreeze to protect the pump and pipes in the cottage.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    I would just set it up for gravity drainage or have it blown out with an air compressor...
    I would not want anti freeze introduced into the supply system.
    Its fine in fixtures and traps.
  6. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Heat tape, maybe!
    My preference would be to install a submersible well pump in the lake with the tank and pressure switch in the cottage. In the winter you could have a drain valve below the water freezing level. Turn off the power to the pump, open all the faucets in the house and then open the drain valve and everything in the cottage (except the commode and hot water tank) will drain back into the lake.
    If you are going to be using this cottage year round I would still mount the submersible pump in the lake and insulate and install a heat tape on the water line from the ground to inside the cottage.
    This should work great unless I am missing something that I'm not advised of here! It beats and above ground jet pump because the pump won't freeze and you never have to prime it.
    This is what we do to cabins, camps and cottages in PA and other freezing areas. The only difference is that the submersible pumps are in the wells.
  7. John Perrie
    Jul 29, 2008
    cottage lake water supply
    I am going to take your advice to install a submersible pump. This solves the concerns with pump and line freezing. Now an underground electric service to the pump in the lake approx. 150' is required. The water line distance from the building to the submersible pump location in the lake will be approx. 150'. w/ a verticle rise of about 15'.
    I will also use the heat tape and insulation surrounded with 6" pipe on the exposed sections and extend that underground 2'.
    I have no knowledge of submersible pumps.
    My concern is sand and debris drawn into the pump. My thought is 6" perforated pipe over the pump and pipe w/ filter fabric (sock) to prevent debris from entering.
    Any recommendations on quality submersible pumps or other ideas.
  8. Bill Arden
    Sep 30, 2006
    computer programmer
    MN, USA
    I still don't see why you don't pound down a sandpoint and use the sandy soil as a large filter.
    Raw lake water contains lots of stuff that I would not want in my water. :p
  9. Redwood
    Dec 15, 2007
    Service Plumber
    Bill here in Connecticut a sandpoint would probably go no deeper than you could dig with a shovel in a few minutes. We have hard mineral deposits that naturally occur in the ground. In most cases drilling or blasting would be required for removal. But that is why I was asking the poster what lake in CT. I have intimate knowledge of many of them.
  10. John Perrie
    Jul 29, 2008
    Ct. cottage water supply
    This cottage will be left unheated during winter months. Toilet design requires no water or plumbing. The lake water supply will be cartridge filterered and used for showers and cleaning, never for drinking.
    Not familiar w/ the term sand point.
    The lake is located north east of Durham. Digging is difficult by hand down to 3' then becomes very hard. The waterline has already been installed 30" deep in the ground and runs underwater to 5' depth.
    1. Surrounding a submersible w/ perforated ads pipe covered w/ filter fabric and raised off the bottom 1' to 2'. Will this design create any problems?
  11. Redwood
    Dec 15, 2007
    Service Plumber
    It would probably be a pretty good set up. 30" deep lines may be a bit shallow in the ground though...
    I suspect other limitations would come into play first though...
    Millers Pond area?
    :cool:
  12. John Perrie
    Jul 29, 2008
    1. Will a submersible pump mounted horizontal in a lake operate correctly?
    2. Does a submersible pump require a sleeve or case over it to function correctly?
  13. ton
    ton New Member
    Jul 3, 2008
  14. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    You can look at Submersible Pumps here and for keeping it clean, I can put the pump inside one of my lake strainers for you. When the bag gets dirty, simply take it off and replace/clean it. This will keep out anything that would plug the pump or it's impellers.
    I just updated my pictures of accessories and need to redo the lake strainer. You can use the link provided there to go to their website where there is a better picture. The link is: Water Well Accessories
    bob...
  15. the mountaineer
    the mountaineer New Member
    Sep 24, 2012
    ny
  16. the mountaineer
    Sep 24, 2012
    ny
Similar Threads: Lake water
Pumps and Tanks Well Forum & Blog. Water is life. May I leave my lake water pressure tank out over winter? Oct 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Keep water line from lake from freezing/ Sep 7, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Problems pumping lake water to cottage Aug 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. lake water pump/tank prssure bounce question Jun 5, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Lake water pump cracked housing - trying to determine best option with changed needs Apr 29, 2014
