tetrisattaque
Hi all. Thanks in advance for any advice. I have a ten year old laing smt 303btw with a dedicated recirculation line that has apparently pooped out. I opened it up and the rotor no longer is spinning when powered on, but the magnetic effect is present. The installation was performed prior to my home purchase and it is lacking the air vent, hose bib, and check valve. Also the pump was installed superior to the top of the water heater which apparently is a no no. However, this system has been working well priorly. I would appreciate some advice.
1. would a roto repair kit fix the pump, or is it totally shot
2. would you rerun all the pipes to have it comply with the manufacturers suggestions even though the prior installation was working for 10 yrs
3. can i just install a watts/grundfos system with the current recirculation line
4 . what would you do
sorry for the many questions
