Laing SM-303-BSW Ciruculating Pump
Discussion in 'Water Heater Forum, Tanks' started by rshackleford, Apr 18, 2010.
  1. rshackleford
    rshackleford New Member
    Oct 18, 2005
    Eastern Montana (The Bakken)
    what kind of pump is it and what does it do? i looked up the pump on the Laing website and the links to manuals don't work. i can't tell if this has a thermostat or if it runs all the time.
  2. Superduper
    Superduper New Member
    Apr 21, 2010
    my shop
    I believe this is a straight circulating pump ... no thermostat, no timer. Apply power, it runs, take off power, it stops. I think this is meant for mounting near the water heater, and powering a recirc loop.
    I have been using a Laing Autocirc pump for about 8 years -- this has a timer and a thermostat, and sits under the sink of my furthest bathroom. Works like a champ. When in the 'on time', it will keep the hot water at a set temp (something like 85 or 90deg) and then shut off. In the 'off time', it doesn't run. You can use a thermostat here, because this is where you want to control the temp. Model: ACT-303-BTW - Autocirc. Designed for a situation where you don't have a dedicated recirc line -- uses the cold water line to push water back to the tank. Warms the cold line up a bit, but not a big deal compared to a hot shower without a 5 min wait (and probaby 10-15 gals of wasted water).
  4. rshackleford
    Oct 18, 2005
    yes this is a straight recirulation pump. it does run all the time. it has worked pretty well and is keeping the kitchen and mud room water at the ready.
    i am considering getting a timer for it and setting it to run a few hours in the morning and evening instead of all day every day.
