Ladder question
Discussion in 'Remodel Forum & Blog' started by r_2016, Jun 30, 2008.
  1. r_2016
    r_2016 New Member
    May 25, 2007
    Hi, I need to get halfway up the peak on my roof and it is kind of steep, do they sell anything that I could attach to the end of an extension ladder that would use the slope of the other side of the roof to hold it so I could use the ladder lay it on the roof all the way up to the peak.Thanks
  2. jimbo
    jimbo Plumber
    San Diego, CA
    I don't know where to buy it, but this article shows the idea: http://paintingyourhouse.info/roof hook 1.htm
    Another technique is to install some roofjacks near the bottom, and a plank. Then lay a ladder on the roof surface, with the base of the ladder resting on the plank.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  5. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    Yes like the other poster described. But you'd likely be looking at a very long ladder. In addition if the roof is extremely steep you'd be fine but if the roof isn't as steep as you think it is you're going to need a fiber glass ladder because you'd bend an aluminum ladder.
    I'd advise you to use roofing jacks but something tells me that isn't going to work for you.
    Tom
  6. hj
    ladder
    Whatever you do, remember to tie the sections of the extension ladder together or the bottom section will slide out of the top one when you put your weight on it. In that case, the top will be secured to the ridge of the roof, and you will be hanging on to the bottom as you leave the roof.
  7. statjunk
    Jun 28, 2007
    HJ,
    That was almost poetic!
    Tom
Similar Threads: Ladder question
Remodel Forum & Blog Window Well Escape Ladders Feb 9, 2012
Remodel Forum & Blog What do you do if you have a 26ft roof and only a 24ft ladder? Dec 5, 2009
Remodel Forum & Blog Installing attic ladder - joists are overlapping Jul 14, 2008
Remodel Forum & Blog Which ladder is better? Apr 10, 2008
Remodel Forum & Blog Choosing an attic ladder Mar 12, 2007
