Lack of Water Pressure
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by NBILL, May 23, 2007.
  1. NBILL
    NBILL New Member
    May 23, 2007
    Could an old water heater cause loss of water pressure? My WH is about 18 yrs old and probably should be replaced. When our outside faucet, or washing machine are on the inside water from the faucets is extremley low pressure. This was not a problem in past years and only started about a month ago.
    Any ideas???
  2. hj
    pressure
    Only if the connections to it are corroded and restricted.
  4. NBILL
    NBILL New Member
    May 23, 2007
    How can you tell if they are?
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Low Pressure
    It sounds like your cold water pressure is also low. That would rule out your water heater as being the source of the problem.
    Possible explanations:
    Main water shut-off not fully opened.
    Water leak.
    The incoming water pressure has dropped from the city or your well.
    your faucet aerators are all limed up and blocking the flow.
  6. AlwaysInHotWater
    AlwaysInHotWater New Member
    Mar 27, 2007
    California
    Are your pipes galvanized?
  7. NBILL
    NBILL New Member
    May 23, 2007
    I just checked the main. I could turn it 4x. I must have not turned it on full when we got back from vacation in January.
    How simple. She is going to try 2 faucets on tonite and see if it is back to normal.
    AlwaysInHotWater---Pipes are copper
  8. AlwaysInHotWater
    Mar 27, 2007
    California
    May all your future problems be so simple. :)
Similar Threads: Lack Water
Plumbing Forum, Professional & DIY Advice Water heater - natural gas - black iron rebuild with flexible CSST Feb 16, 2016
Plumbing Forum, Professional & DIY Advice Repairing a pinhole leak in old black plastic water main. Jan 25, 2016
Plumbing Forum, Professional & DIY Advice Water help needed - Sulfur smell, bad taste, black sediment Jan 28, 2015
Plumbing Forum, Professional & DIY Advice Black Water w/particulates - hot side only - well Dec 2, 2014
Plumbing Forum, Professional & DIY Advice Black on Cold Water Line Jan 18, 2014
