Kohler Villager being used in a basement bath remodel, drain and trap in concrete
Discussion in 'Shower & Bathtub Forum & Blog' started by Father of 4, Mar 27, 2013.
  1. Father of 4
    Father of 4 New Member
    Mar 27, 2013
    Lesterville, MO
    New member here, have learned much in the past couple hours...thanks for the information on the Kohler Villager tub! I have done a few bath reomodels, but never before have I tackled a cast iron tub install!
    I have two questions...the prior fiberglass shower/tub combo was raised up on a 2x6 so that it was 5 1/2" higher than floor level. I have no wiggle room with the tub drain, there is no way to get the existing drain lower than the 2 1/2" it currently sets at. Since it's on concrete, I can think of no way of getting the new Villager tub installed without raising it up on some sort of platform as well. That said, I'm thinking of a ledger on the back wall at about 4" higher than "normal" and some sort of support (masonry?) in the front that will get it raised up the same height in front.
    Second, have you found that the 1 5/8" required distance from wet wall to middle of drain is required or can I alter the drain in some way to use the drain that I currently have (again, in concrete) where it is at? the current distance from the roughed in wet wall to the middle of the drain is 2 5/8".
    Thanks in advance for any input you can give!
  2. Terry
    Aug 17, 2004
    How about a picture of what you have?
    800 pixels or less
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Concrete cuts like butter with the right tools.
    Without seeing what you have to work with, it's hard to give you any advice on what your options are.
  5. Father of 4
    Mar 27, 2013
    Lesterville, MO
    If my possible solution doesn't work, I'll get a pic uploaded...what I relized is that I could cut the overflow pipe and put in a 1 1/2 flexible/telescoping fitting (the thin plastic stuff, not sure what it's called) and it would allow me to get the overflow an inch closer to the tub than it would normally be. I'll find out this afternoon as I am going to give this a try.
Similar Threads: Kohler Villager
Shower & Bathtub Forum & Blog Help, cast iron install questions. Kohler villager Nov 2, 2015
Shower & Bathtub Forum & Blog Fiberglass surround for Kohler Villager? Apr 9, 2015
Shower & Bathtub Forum & Blog Steel tub tear out / Kohler Villager install - Alcove - Block Wall Jun 7, 2013
Shower & Bathtub Forum & Blog Kohler Villager (K716) vs Kohler Bellwether (K838) Aug 26, 2012
Shower & Bathtub Forum & Blog Size of ledger for Kohler Villager cast iron tub? Jul 12, 2010
