Kohler valvet question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by analogguy, Dec 28, 2012.
  1. analogguy
    analogguy New Member
    Feb 28, 2008
    California
    I have to replace a Kohler valvet stem assembly (hot side) and was wondering if there is a trick to installing it correctly. Should the valve be all the way open or all the way closed when installed? I've read somewhere that if done incorrectly the handle will just keep spinning and will not work. Thanks.
  2. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    keep the stem half closed. Tighten it by hand ensuring that the stem can spin freely until the bonnet is tight. Why not replace the hot and cold at the same time while the water is off? Do not apply any grease on the stem, have had them open by itself after using greaseon the stem (brass barrel type).
  4. hj
    Anything except "closed". You have to hold the stem while tightening the bonnet or it will open or close itself, depending on whether it is a right hand or left hand stem. If it opens, no problem, if it closes, you will NOT be able to tighten it properly.
  5. analogguy
    Feb 28, 2008
    California
    Problem solved. Thanks to all..you guys are the greatest!
Similar Threads: Kohler valvet
Plumbing Forum, Professional & DIY Advice Kohler Valvet (I think) conundrum Sep 25, 2009
Plumbing Forum, Professional & DIY Advice Please Help Me Find a single Chrome-KNOB that fits a Kohler 30467 diverter stem Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Kohler Forte Tall Single Lav Repair, K-10217 Jan 14, 2017
Plumbing Forum, Professional & DIY Advice 1970s(?) Kohler/Bradley/Cole Shower Control Leaks Dec 13, 2016
Plumbing Forum, Professional & DIY Advice Kohler Archer acrylic install question Dec 12, 2016
