Kohler tub drain assembly
Discussion in 'Shower & Bathtub Forum & Blog' started by Kerri, Aug 16, 2013.
  1. Kerri
    Kerri New Member
    Aug 16, 2013
    california
    I converted my Kohler tub to a walk in shower by having the Tubcut people modify it (worked great by the way.) Now I never need to close the tub stopper because I never want the tub to fill with water.
    The tub drain was very slow and so I took the overflow thing apart and pulled out the stopper control arm and found that the spring in the stopper assembly was full of hair.
    Do I need that spring in there? The tub is draining fine now, and as I said, I never want the tub stopper closed. I did not put the spring/arm back because it will just get clogged again and I don't need the stopper to close.
    The tub drains to a greywater system, not to septic or sewer pipes.
    What could go wrong with that spring removed?
    Kerri
  2. Terry
    Aug 17, 2004
    You only need the spring if you intend to use the stopper.
  4. Kerri
    Kerri New Member
    Aug 16, 2013
    california
    That's great news. Thanks so much for your excellent website.
Similar Threads: Kohler drain
Shower & Bathtub Forum & Blog Which Kohler Archer drain do you prefer? Jan 16, 2017
Shower & Bathtub Forum & Blog Drain shoe gasket will not seal on new Kohler acrylic tub Jun 8, 2014
Shower & Bathtub Forum & Blog Question about finish on kohler castiron tub drain pic attached May 1, 2013
Shower & Bathtub Forum & Blog Kohler Villager being used in a basement bath remodel, drain and trap in concrete Mar 27, 2013
Shower & Bathtub Forum & Blog Kohler k9132 Shower drain Jan 12, 2013
