Kohler toilet seat replacement for one-piece.
Discussion in 'Toilet Forum discussions' started by felipe, Dec 11, 2007.
  1. felipe
    felipe New Member
    Dec 11, 2007
    California
    I have a one piece kohler toilet and am trying to replace the seat. the problem is that one of the anchor screws will not come out of the toilet. I keep turning it (unscrewing it) but it appear to be stuck. how do I get it out? any suggestions? i've looked at the kohler site but have not foun any useful information.
    i'm thinking of cutting the screw in order to pull it out.
    any suggestions?
    felipe
  2. grazzy
    grazzy New Member
    Nov 1, 2007
    Virginia
    can you reach the nut on the other side from inside the tank? might need to hold that with pliers so you can unscrew the bolt.
  4. Impreza5150
    Impreza5150 New Member
    Dec 20, 2007
    Indiana
    As of today, I am having the same issue.
    I think there is some sort of an anchor system used on our toilets.
    Here is my story -
    My seat has never been snug since I'd bought my house. After having enough of it, I popped the caps on the back of the seat and took a flat-head screwdriver to them..... They just spun w/ no backing out and no tightening up.
    There is no way to get to the back side of our seat mounts. No nut under the tank, inside the tank- Its all contained.
    FINALLY I just broke the seat off the commode, and pried the anchor-type securement out of the holes. It appears that the previous owner over-tightened them and snapped it.
    I took it to Lowes and they were no help. They told me to visit a specialty tool supply store.
    I've done all I can do to find a part number or a diagram online....
    I'm at a loss as well. :confused:
    Expensive toilet..... no parts..... Great.....
    Anybody?? Bueller?? Beuller??
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Cut the head of the screw off with a hacksaw. After that the anchors fall through. The new seat comes with anchors.
    With kohler just use the phone their web site is useless!
    1-800-4-kohler
    Personally rather than play with junk that is hard to work on and get parts why not install a nice new Toto Drake!
  6. grazzy
    grazzy New Member
    Nov 1, 2007
    Virginia
    on my one piece units (san raphael and rochelle) the nut for the seat bolt is reachable from the tank. i would not buy a replacement seat from kohler, as it will run as much as a new toilet. there are aftermarket products, but watch the color ... there's a kohler color table at this link
    http://www.us.kohler.com/designkb/colors/timeline_1990.jsp
    a company called church makes some replacements or you can google "kohler toilet seat" and find several manufacturers. and there's always ****. with shipping you can get one for less than $40. i bought one for less than $20 new in the box, but alas, the blue was not HERON BLUE that matches my 20 year old units. good luck.
  7. birdbonker
    birdbonker New Member
    Mar 26, 2008
    New York
    how to change seat on Kohler 1-piece toilet
    I am trying to change a toilet seat. This is a Kohler one piecce toilet over 10 years old. inside the lid are the following numbers: T 54, K45E0 (the E looks like a backward 3) 21820, 2 2087.
    the old seat was screwed into what looks like a nut, which is now rotating with every turn I make, thus I am making no progress. Also, the screw is much smaller in diameter than the hole. Once I get the seat off I don't see how I will get to replace it...:confused:
  8. Redwood
    Dec 15, 2007
    Service Plumber
    Cut the screw. The insert will push inside the toilet. You need to get new kohler mounting screws.
  9. pretendplumber
    pretendplumber New Member
    Mar 24, 2009
    California
    Koler one-piece seat replacement
    I have a similar problem, the seat anchors are broken and kohler does not provide replacement anchors with the seat that they recommend for the model toilet.
    I contacted kohler through the website e-mail address and they wanted $47 for the 2 anchors and a special tool to remove the old anchors. I replied that I did not need the $46 tool, just the $1 anchors. Their response was to offer a small discount.
    Desperate to attach the seat, I inserted a large plastic anchor and, although loose, the seat is attached.
    I have since found a manufacturer, Bemis, who apparently sells a kit to attach their seat to the Kohler one-piece. I've not contacted them yet, but I'll post if I'm successful.
    What really bother's me about Kohler, is that at the same time I bought the toilets, I replaced the faucets with Moen products, which come with a lifetime guarantee. After a few years, the white coating on the faucets chipped and Moen replaced both faucets at no charge. I suppose Kohler is comfortable enough with their position in the market to not care about repeat business.
    Good luck. :)
  10. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Good points...
  11. Redwood
    Dec 15, 2007
    Service Plumber
    Kohler Proprietary Designs can sometimes be a bit complicated and a wee bit expensive...
    Take this toothpaste dispenser as an example...
    It costs more than a coffee maker on a USAF C-5A Transport Plane....:eek:
    [​IMG]
  12. jtlapal
    jtlapal New Member
    May 24, 2009
    Switzerland
    Kohler Pain in the Toilet Seat
    I bought a new Kohler toilet seat that seems to fit the toilet.
    However, there is not way of getting to the area where I would expect to put on the nuts.
    As the previous poster says, it appears to be completely enclosed.
    If this means I have to replace the toilet, it definitely won't be another Kohler.
    Is there any other way of attaching the toilet?
    Thanks
  13. kingsotall
    Aug 17, 2008
    Can you post some pictures of your dilemma¿
  14. jtlapal
    jtlapal New Member
    May 24, 2009
    Switzerland
    I will see if I can figure out a way to phtograph it that will have meaning. The top is just the two holes. There is no other way that I can figure out to access the area I would expect to attach the nuts.
    The rest of the outside is just the toilet exterior. Inside the tank the area where the nuts might go is just closed off. There is no exterior access either.
    So either they have some magical way of mounting it that isn't for sale at Home Depot, (even when you buy a Kohler seat), or I will just have to live without a seat on this toilet until I replace it. We have other toilets. But it is a bit inconvenient.
  15. alan mayer
    alan mayer New Member
    May 25, 2009
    California
    part number is 84999 but there is an easier way
    I found this posting concerning the same issue.How to repair/replace a Kohler seat that has the anchor bolts
    If you have a Kohler toilet that requires the Kohler seat anchor kit 84999, here is an inexpensive alternative
    Step 1
    If you have one of the Kohlers with the Kohler anchor bolts holding the seat, do not buy the $46 anchor bolt kit 84999.
    Step 2
    Instead, remove the old anchors and bolts which have an aluminum end which the stainless bolt screws into and over time become corroded together. Use a 1/8" drill and drill around the bolt removing the anchor material until the bolt can be pulled out.
    Step 3
    Carefully clean the hole with a 11/32" drill to remove all the remaining anchor material.
    Step 4
    Then go to your local hardware store and buy a 10-32 3/8"x3/4" rubber expansion plug (check to be certain the threaded part is brass and it has a shoulder on one end), a 10-32x1.5" Phillips bolt and a couple of small fender washers to fit the seat. Total cost under $4.00 for two.
    5.
    Step 5
    Assemble being careful to not tighten too much and crack the porcelain.
    hope this helps. remember be careful not to chip the porcelain
  16. jtlapal
    jtlapal New Member
    May 24, 2009
    Switzerland
    Thank you!
    Alan,
    That seems like an excellent idea!
    I will go and get one and try it.
    Joe
  17. jtlapal
    jtlapal New Member
    May 24, 2009
    Switzerland
    Of course, I found out, trying to find 10-32 3/8"x3/4" rubber expansion plugs is not that easy. They didn't have them at HD (or at least no one knew where they were if they did). I went to True Value Hardware and they had every size but.
    I tried a size larger and they wouldn't fit in the holes. So now I go on the great rubber expansion plug safari.
    Joe
  18. kingsotall
    Aug 17, 2008
    You will undoubtedly meet many a handyman on your journey...
  19. hj
    plug
    Try an auto parts store, such as Checker.
  20. DIYplumber1932
    DIYplumber1932 New Member
    Jun 7, 2009
    Diamond Bar, CA
    how to replace the one piece toilet seat
    remove the toilet seat by cutting the plastic piece , then use metal saw to cut the bolt and remove the old particle
    to install the new one use the Hollow wall anchors you could get it in any hardware store, in this case i use 6-32x1-1-1/2 with a few ring and should resolve the issue with less than $5
    hope this will help for DIY people
  21. jj93rx7
    jj93rx7 New Member
    Sep 7, 2009
    Salinas, CA
    Toilet Seat Replacement
    I had the same problem. I took the existing screws out that were stripped. You may have to cut the heads of the screws off with a hacksaw. Make sure you leave enough of the screw so you can grab it with a plier and remove it. The only thing that worked for me was 3" plastic wall plug. I think thats what it is called. You put into a sheet rock wall and screw in a screw and it expands so you can mount things on the wall. I tapped the plastic plug into the two holes in the toliet where the seat mounts. I then placed the toliet seat on top of holes and screwed in the mounting screws. The plastic wall plugs expand securing the toliet seat. So far the seat does not move. We will see after several more uses.
    Good luck. E-mail me if you have questions. jj93rx7@comcast.net
Similar Threads: Kohler toilet
Toilet Forum discussions Kohler toilet makes leaking sounds, but never refills Today at 12:30 PM
Toilet Forum discussions Kohler K-3406 San Miguel Toilet fill valve . . . Feb 1, 2017
Toilet Forum discussions Kohler Odorless Toilet, Odor Neutralizing Jan 19, 2017
Toilet Forum discussions I have a Kohler wall mount toilet with a Geberit wall mount tank/ carrier Dec 13, 2016
Toilet Forum discussions Kohler Memoirs 3 Bolt Toilet Tank Nov 30, 2016
