hoe moaner
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I had a Kohler single handle shower vale (forte K-T10274) installed as part of a recent bathroom remodel. The installer tested for water flow, but not temperature. Now the remodel is finished, and I went to use the shower. I find it delivers only cold water. I removed the handle and checked the temp regulator set screw. It is about centered in the fitting. I opened the valve to full with the handle removed, and the valve stops before it gets to the set screw. There is about a quarter inch gap between the end of the set screw and the stop.
Is there some kind of an internal stop mechanism in the valve? Could the valve be installed upside down in the housing?
