Kohler Shower valve, need help identifying a piece
Discussion in 'Shower & Bathtub Forum & Blog' started by ROCNDAV, Dec 18, 2007.
  1. ROCNDAV
    ROCNDAV New Member
    Dec 18, 2007
    Los Angeles
    I have a Kohler shower valve that leaks like crazy. I finally had some time Sunday evening to look at it. Upon disassembling the shower valve, I see its an unusual design (I'm no professional, but I have never seen a design like this). I wish I would have taken pictures of the pieces, but it was late and I had to do something. I've created a paint drawing and attached it.
    The lever turns a shaft which is threaded, which sends an actuator in and out. on this actuator are two slip fit cylindrical pieces that house the O-rings (one for hot, one for cold). The O-rings butt up against these two brass fittings. one of the brass fittings has worn away (possibly due to debris in the line?), and unable to form a seal against the oring.
    These fittings are almost the diameter of 1/2" copper tubing on the oring mating side. The threaded size (which threads into the housing) is 11/16-27.
    Does anybody know what these pieces are called so I can order replacements? If not, do you know what this style/design of shower valve is called? Kohler's site only has newer design shower valves and is no help.
    Thanks in advance.
    [​IMG]
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Go tokohlers web site give model #.
  4. ROCNDAV
    ROCNDAV New Member
    Dec 18, 2007
    Los Angeles
    I have been on their site, thats the problem, it is an older unit, and I cant find the model on their site, nor the model number any where on the valve assembly.
Similar Threads: Kohler Shower
Shower & Bathtub Forum & Blog Kohler Niedecken, Need information on very old shower mixing valve Dec 8, 2015
Shower & Bathtub Forum & Blog Kohler Archer Shower Base Install Dec 7, 2015
Shower & Bathtub Forum & Blog ***Kohler Shower Valve replacement ***HELP Sep 18, 2014
Shower & Bathtub Forum & Blog Need help fixing a Kohler shower faucet Jun 20, 2014
Shower & Bathtub Forum & Blog What is causing my Kohler K-304 shower to turn on. May 10, 2014
