Kohler shower valve leaking
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Terry, Dec 8, 2008.
  1. Terry
    Aug 17, 2004
    Leaking Kohler faucet,
    Anyone know which cartridge for it?
    This picture sent by a homeowner.
  2. jimbo
    jimbo Plumber
    I started to say Coralais, but the handle is not quite right, and the trim also. I guess I would need to see the cartridge, but one of the guys will probably know it right away when they see it!
  4. Terry
    Aug 17, 2004
    It may be the K-304 valve
    [​IMG]
  5. hj
    My experience has been that it doesn't make much difference. IT is often the pressure balancing unit which splits at the seam, (you can tell because there will usually be a white deposit at the point where the seam separated), causing the leak, and that is pretty much generic to all Kohler valves.
Similar Threads: Kohler shower
Plumbing Forum, Professional & DIY Advice 1970s(?) Kohler/Bradley/Cole Shower Control Leaks Dec 13, 2016
Plumbing Forum, Professional & DIY Advice How to Remove Kohler Shower Valve Handle Sep 29, 2016
Plumbing Forum, Professional & DIY Advice Trying to remove the Faceplate on a Kohler Shower Faucet. Tried Everything. Help! Jul 18, 2016
Plumbing Forum, Professional & DIY Advice Kohler shower only cold water May 14, 2016
Plumbing Forum, Professional & DIY Advice Kohler Purist - Shower set K-T14422-4-CP Nov 28, 2015
