Kohler shower caukless adaptor tricks?
Discussion in 'Shower & Bathtub Forum & Blog' started by T_Hartigan, Mar 10, 2012.
  1. T_Hartigan
    T_Hartigan New Member
    Nov 28, 2006
    Spent about 2 hrs trying to install a kohler shower drain. I cannot get the caulkless adaptor piece all the way down. I've soaped everything and just cannot get it installed.
    Any tricks?
    Thanks.
    Tim
  2. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    Is the pipe coming up through the drain vertical or is the pipe off to one side not allowing the gasket to slide down? What kinda pipe is it?
  4. Terry
    Aug 17, 2004
    I sometimes split off some wood to the correct size and use it as a blunt chisel to push the rubber seal down. Make sure it's flat on the end so it doesn't split or tear the rubber seal. You can tap the wood tool you made with a hammer.
  5. T_Hartigan
    Nov 28, 2006
    Thanks. The PVC pipe was centered, but not perfectly square to the drain. I did use a mallet to get it down. I hope it doesn't leak as I dont want to do that again, ever.
    Tim
  6. curlysir
    curlysir New Member
    Sep 21, 2009
    Texas
    I used a carpenter pencil and a plastic headed hammer to install the seal on my drain I installed recently. The pencil was the only thing I had close at hand and it worked. These seals are a real pain in the rear to install. I hope they are good.
  7. Hackney plumbing
    Jan 6, 2010
    Alabama
    I have a trick to install those on PVC pipe........But it is classified info. Top secret. I MIGHT would share it with Terry since it is his forum.
Similar Threads: Kohler shower
Shower & Bathtub Forum & Blog Kohler Niedecken, Need information on very old shower mixing valve Dec 8, 2015
Shower & Bathtub Forum & Blog Kohler Archer Shower Base Install Dec 7, 2015
Shower & Bathtub Forum & Blog ***Kohler Shower Valve replacement ***HELP Sep 18, 2014
Shower & Bathtub Forum & Blog Need help fixing a Kohler shower faucet Jun 20, 2014
Shower & Bathtub Forum & Blog What is causing my Kohler K-304 shower to turn on. May 10, 2014
