Kohler Rialto K-3402-PB toilet
Discussion in 'Toilet Forum discussions' started by rdema19403, Apr 8, 2008.
  1. rdema19403
    rdema19403 New Member
    Mar 3, 2006
    I have a Kohler Rialto (model # K-3402-PB) toilet and I just replaced the Cap Plunger Kit any how after I replaced it the toilet reservoir fills up but I can still hear water running If I go to the water meter you can still see the water meter running. If I pull up on the float ball a little the water stops running. Any ideas what would be causing this?
    Thanks in advance,
    Ralph
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  4. ron in sc
    ron in sc New Member
    Mar 30, 2005
    South Carolina
    I don't know if your Rialto is the older model that used 3.5 gallons to flush or not but if it is I'd rebuild it. I have a Rialto that I installed in 1988 and I have no complaints. I think it's gotten stopped up less than half a dozen times in 20 years. I did have to rebuild it a few years ago as just about all the internal parts were worn out or corroded.
    I installed a Toto Drake in my detached garage yesterday and it was very simple and easy to install. I also installed a Toto ADA height Ultramax in our new downstairs master bedroom suite that's nearly finished.
    Totos are my choice for replacement but I also like that old Rialto. The other Kolher toliets in the house are old Wellworth Lites that I definately would not recommend.
    If you are going to replace your Rialto I be very interested in acquiring it, if it's the old model.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    As always the only thing wrong with the rialto is the cost of parts!
  6. grazzy
    grazzy New Member
    Nov 1, 2007
    Virginia
    the 1B1X after-market replacement is now available at Lowe's for $9.99.
Similar Threads: Kohler Rialto
Toilet Forum discussions Need to replace an old Kohler Rialto Jan 5, 2016
Toilet Forum discussions Kohler 3402 Rialto toilet ? Replace parts or use conversion kit? Oct 12, 2015
Toilet Forum discussions Kohler Rialto K-3402 Footprint diagram Mar 29, 2015
Toilet Forum discussions Kohler Rialto(?) flapper valve replacement Sep 25, 2014
Toilet Forum discussions Kohler Rialto toilet 1984 Nov 23, 2013
