Kohler overflow installation question w/ pics...ASAP please!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by zubz, May 14, 2010.
  1. zubz
    zubz New Member
    Apr 5, 2010
    NJ
    Hi All,
    I am installing a Kohler Archer tub and slotted overflow. NOt sure if anyone has experience with this overflow. It has a swivel ball construction. I am not sure if I am going about the installation correctly.
    Should the hub going over the ball be "attached", meaning I should not be able to seperate them? This does not seem possible to me. Even after tightening I call put the joint apart. Is that normal?
    Hard to explain...but I attached pics that hopefully helps.
    Thanks
    Jason
  2. zubz
    zubz New Member
    Apr 5, 2010
    NJ
    Manufacturer picture
  4. zubz
    zubz New Member
    Apr 5, 2010
    NJ
    One more item to add. Here is a link to the installation guide. If you notice step #3 already shows part of these pieces I took a pic of assembled, but doesn't show how it stays attached. Then if you go to the part section on page 14, it shows them not seperated, which is the way they came in the box. Any ideas??
    http://www.us.kohler.com/onlinecatalog/pdf/1069650_2.pdf
  5. hj
    Something has to hold the nut over the "swivel". You cannot slide the nut over it and then expect it NOT to slip back off. I would suspect that the black gasket goes between the top of the "ball" and the nut to retain it.
  6. zubz
    zubz New Member
    Apr 5, 2010
    NJ
    That worked. Thanks HJ. Believe it or not, your one paragraph was clearer then the instruction booklet. Thanks again.
Similar Threads: Kohler overflow
Plumbing Forum, Professional & DIY Advice Help!! How do I connect the overflow and drain assy to my new kohler tub? Sep 8, 2010
Plumbing Forum, Professional & DIY Advice Help!! How do I connect the overflow and drain assy to ny new kohler tub? Sep 8, 2010
Plumbing Forum, Professional & DIY Advice Please Help Me Find a single Chrome-KNOB that fits a Kohler 30467 diverter stem Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Kohler Forte Tall Single Lav Repair, K-10217 Jan 14, 2017
Plumbing Forum, Professional & DIY Advice 1970s(?) Kohler/Bradley/Cole Shower Control Leaks Dec 13, 2016
