Neal S
- Messages
- 1
- Reaction score
- 0
- Points
- 1
How to remove a rubber glove stuck in the passage between tank and bowl? I recently received a call for a slow flushing toilet. Tech sent snaked, checked flapper, fill valve, etc. All were operating normally. The only problem he found was the water leaving the tank was glugging and not swirling.
After calling an outside plumber and removing the toilet, it was found that a rubber glove made its way into the tank and was stuck in the lower bowl area. Only seen with a small inspection mirror. We tried mechanical fingers and wires to try to pull out the glove. No luck.
Does anyone have any suggestions?
