Kohler Cimmaron
jeff45
I read the previous post on this toilet. I recently bought the Kohler Cimmarron and installed it in a 2nd floor bathroom I added. When I flush the toilet it flushes rapidly with an initial bubble of air as it is flushed. The bowl also does not fill up very much after the flush is complete. It has its own vent and there is no leakage anywhere. There is no clogging issues since the toilet and piping system has not been used. What would be causing this? Does this sound like a problem with this particular toilet? I'd appreciate any advice. Thanks! Jeff
Plumber1
Florida
water level
Check for the normal water level by holding the float down and allow the water to rise as far as it can in the bowl. That's where the level should be.
Now make sure that the refill tube is set to flow into the overflow tube and that there is water flowing .
