I recently purchased and installed a Kohler Cimarron with the Drylock system. Once I got it all installed and added water to the tank, the water flowed out of the tank as though there were no gaskets. Seems the Flush Valve inside the tank is loose and the leak is from the between the valve and the procelain. I tried to remove the hex nut that holds the assembly in place but it won't budge - I'm thinking it may have been put on skewed and is now stripped. Kohler is sending me parts but since I cannot remove the nut (without maybe cutting it) I'm not sure if that will help or not. Is the flush valve supposed to be flush and tight against the porcelain? should the drylock plate be loose like it is? Any help would be appreciated.
Thanks,
Jim
