Kohler cast iron tub
Just1
NYC
Hi all. I'm getting ready to tile the floor in my new bathroom and I have a question regarding the Kohler cast iron tub apron. The room was squared up and walls plumbed before the drywall and cement board went up and the tub was installed tight to the studs. Now that I am measuring and cutting the tiles to fit next to the apron I'm noticing that I have to cut most of them on a slight angle to follow the tub with a consistent caulk gap. Is it possible that the tub is not 100% square or true? Thanks in advance.
Just1
NYC
More likely that the floor was out of level. I normally check that with a level first, and make sure I'm installing the tub level.
https://terrylove.com/forums/index.php?threads/installing-a-kohler-villager-cast-iron-tub.33212/
Terry thanks for the quick reply. I don't think you understand what I'm trying to say though. The tub is installed level from front to back and side to side. I'm referring to the floor tiles that butt up to the front skirt or apron of the tub. Not the tub flange or tub ledge. In other words if I measure from the drain side of the tub to the wall across from it I get a number and when I measure the other side of the tub (non drain side) to the wall across from it I get a number that is 3/8" more.
Just1
NYC
I have worked in a lot of places, and not one was perfectly square.
Ok so I just measured from end to end the long wall the tub is against to the wall directly across and parallel to it. The measurements are within a 16th so it does seem like the room is pretty square.
MKS
Illinois
It sounds like the two walls are not parallel. If you haven't already installed tiles you can decided where to hide the error.
Just1
NYC
The walls are parallel. They are only off by a 16th of an inch in 7 feet. I would say that's pretty square.
MKS
Illinois
So pull the tub and measure it up or determine what site lines are important to the overall tile installation and forget about square plumb and parallel.
Just1
NYC
No reason to pull the tub at this point. Walls are up and waterproofed. The tub was installed tight to the studs and it's completely level. I was told by one of the employees at the plumbing supply that cast iron tubs are rarely perfectly square. I was just wondering if you guys agree with that.
MKS
Illinois
Part of the finishers job, floor, trim, is to make the out of plumb, square, parallel stuff disappear. Make it pleasing to the eye not measuring devices.
Dj2
California
I'm willing to bet that the problem is in the way you laid the tiles (which are not all the same size, even if they look the same).
Just1
NYC
You have a good point. The tiles are close but not perfect because they aren't rectified.
Normally you would center the tile in the room, making the cuts at the four walls.
I would never expect to be able to lay a floor without cutting tile.
Just1
NYC
Who said anything about not cutting tile?
