Kohler canister flush valve question
Discussion in 'Toilet Forum discussions' started by Peterson, Sep 1, 2013.
  1. Peterson
    Peterson New Member
    Sep 8, 2007
    PA
    I was at Home Depot yesterday and there was a Kohler toilet tank sitting out on a shelf (someone must have taken it out of the box or something). It had a canister flush valve that looked to be the same diameter as a standard flapper flush valve. They called it their "aqua piston" something.
    Would it be possible if someone were to buy a new Kohler Wellworth toilet, remove the canister flush valve, and put in a regular flush valve with a flapper? Would the toilet work fine? I can just see the canister failing if someone had very hard water.
    [​IMG]
  2. GoKohlerGo
    GoKohlerGo Brand New Plumber
    Aug 11, 2012
    Michigan
    The flapper would fail way before the canister would. The canister is made of plastic, while the flapper is made of rubber. I would recommend that you keep the canister in the tank. It gives more flush power. But if you really want to, you can replace it by turning the water supply off, flipping the tank over, and with tongue and groove pliers, put them on the white nut, and turn it counter-clockwise until the canister gets loose and can come out. To install the new flapper, put the new flapper in the hole at the bottom of the tank, put the new nut on it, and turn it clockwise until it is snug. Then, just put the tank back on, re-connect the water supply, and you'll be good! Hope I helped!
  4. Terry
    Aug 17, 2004
    It's pretty easy to change the seal on the Piston. Unthread the keeper on top and lift out the cannister.
    [​IMG]
    I don't think there is a need for conversion. I would use it "as is" out of the box.
    With hard water, you will have maintenance no matter what you install.
  5. jadnashua
    Can't think of a reason why it would work better, but it is different, keeping in the tradition of NIH that infects Kohler.
  6. Peterson
    Peterson New Member
    Sep 8, 2007
    PA
    Thanks guys! I'm not in the market for a new toilet, but I liked the looks of the Kohler if I was.
    I was just curious about changing out the canister if I should happen to buy a Kohler. I wouldn't want to buy something and then run into the problem of not being able to get parts, etc. where I could always buy flapper anywhere if needed. I also read on this forum about the canister getting stuck, or falling too quickly, etc.
    I have an older Mansfield in my house and years ago I removed the flush tower and installed a flapper valve in the tank and it works great, if not better. I was wondering if the same would apply to the Kohler.
  7. Terry
    Aug 17, 2004
    I'm tracking a few with the cannister valve and they seem to be working.
    These are Kohler products I've installed in the last year.
    The wholesale outlets I buy from have the parts. I have not paid much attention to the home centers. I'm not in those places much.
    We have also done the seal repair on the new flush valve, so it's all doable by a DIY.
  8. Starwarsith88
    Starwarsith88 DIY kid who loves toilets
    Aug 20, 2013
    Sparta NJ
    We have recently got a new Kohler Cimarron Class 5 with an Aquapiston Canister, the toilet is really great, I recommend to keep the aquapiston, much more reliability and sealing on the Aquapiston.
  9. EMK800F1
    EMK800F1 New Member
    Sep 5, 2013
    Mech Engineer
    Indiana
    Per Kohler's spec sheets, the Cimarron has "AquaPiston" and others (e.g., Welworth) have a "Class 5" flushing system.
    Are these two different ways of marketing the same thing?
    Ed
  10. Starwarsith88
    Aug 20, 2013
    Sparta NJ
    This is true, The Aquapiston is class 5 as well. The wellworth and other class 5 toilets come standard with an aquapiston.
  11. jadnashua
    As I've said before, 'Class x' is a totally Kohler marketing thing and has no general industry standard. Each time they try to make it more efficient (either in cost or performance), it 'obviously' must be better, and they bump the class designation up - the implication is that if the class is higher, it must be better. So, only practical experience will show (eventually) whether there is actually any improvement, and in the meantime, the parts catalog keeps getting bigger making it harder for anyone to find the right part for their now orphaned design. 98% of the rest of the industry keeps the mechanical parts the same and refines the guts in the porcelain. After all, how many times do you need to redesign the fill valve, and flapper valves have been around for probably close to 100-years or more. But, Kohler likes the fact they designed it (aka, NIH, not invented here syndrome) even if the part ends up costing 3x as much and parts aren't reasonably available and it doesn't necessarily work better (just different!).
    Contrast this to Toto, who obviously does change things, but has one fill valve that can replace nearly all of the toilets sold over the last few decades. It has a little dial, and depending on the model you have, you look at the chart and set it there, and the bowl/tank ratio of fill is proper and it plain works.
    They do make some nice stuff, but personally, I think there are often some better alternatives.
  12. EMK800F1
    EMK800F1 New Member
    Sep 5, 2013
    Mech Engineer
    Indiana
    Actually, I was able to communicate with someone from Kohler, and the AquaPiston is NOT the same as the Class 5 system. I believe it has a slightly larger diameter to the cylinder, and it recently started shipping with a silicone seal.
    I do not know if the two are interchangeable, but I would guess not.
    Ed
Similar Threads: Kohler canister
Toilet Forum discussions Kohler toilet--fill valve pops out of canister Sep 21, 2016
Toilet Forum discussions Kohler Canister toilet clogs Jul 7, 2016
Toilet Forum discussions Replace Kohler canister type flush valve Aug 13, 2014
Toilet Forum discussions White filler tube keeps popping off Kohler canister valve Jan 30, 2014
Toilet Forum discussions Kohler canister flush valve drops too quickly Jan 29, 2012
