Kohler makes a deep rough-in kit for some of their faucets. Sometimes the counters are too thick, or sometimes in this case, the counter installers will have placed their holes too close to the undermount lavs. The 1131486 kit allows you some options.
Kohler Deep Roung-In Kit 1131486
Normally you can install using the parts that come with the faucet.
This was close, but it worked.
The next bathroom was too close for the standard parts to work.
Even looking down, you could see that the lav was in the way. In this case I picked up a diamond hole saw and cut out the hole better.
To make this work, I cut a portion of the large washer, but it worked.
I had asked the counter installers for more space, but they insisted that all plumbers had to shim when they were done. In this case shimming was impossible. The extended threading of the adapters allowed it to work.
