Kohler 1-piece toilet - water fill valve replacement
Discussion in 'Toilet Forum discussions' started by clement, Jun 18, 2006.
  1. clement
    clement New Member
    Jun 18, 2006
    I have a Kohler one piece toilet (K3402PB). The fill valve can't shutoff. I opened up the the valve (K-9269) and found out that the plastic riser rim that is in contact with the plunger has worn out.
    The valve has a 1 inch tube connecting to the back of the toilet. The fill water level of the toilet is about 5 inches.
    Can someone recommend a replacement valve. Also what type of modifications do I have to make in order to get it to work.
    Thank you
  2. Sponsor
  3. hj
    fill valve
    Home Depot has a Coast 1B-1X fill valve for toilets like yours. Its large plastic tube works better if you cut it short, and then also cut the Kohler's tube off and slip the new one inside the original tube.
  4. clement
    clement New Member
    Jun 18, 2006
    Coast 1B1X
    Thanks hj, for the recommendation.
    The problem I have now is Home-Depot in Canada don't carry Coast 1b1x. I tried other plumbing stores but they don't have it either. Is there any other brand that I can try?
    Also, I searched the website of Home-Depot for the 1b1x valve. It returned with 0 item found. Is it possible that the valve is listed with another in-store stock number?
    Thanks
  5. rldev
    rldev New Member
    Aug 24, 2005
    New Jersey
    Any word of this? I have the same exact problem.
  6. hj
    fill valve
    Check Home Depot again. See if they have a fill valve that costs almost $20.00, rather than the $6.00 ones. If so, that is probably the right one, they just don't know it.
  7. grazzy
    grazzy New Member
    Nov 1, 2007
    Virginia
    i picked one up at lowe's in VA tonight for $8.99; they apparently just started carrying them after i bought a CESCO BRASS unit just last week for $58. :eek:
  8. grazzy
    grazzy New Member
    Nov 1, 2007
    Virginia
    i've often wondered if you couldn't just rig up a fluidmaster to fit that tube by running the fill line into the plastic line in the kohler tank. you'd need some way to hold the big plastic line up so it wouldn't siphon all the water from the tank into the bowl, but that could be done with an elbow and a clip i believe.
  9. CoastProductsUSA
    CoastProductsUSA In the Trades
    Aug 21, 2011
    Panama City Beach, FL
Similar Threads: Kohler 1-piece
Toilet Forum discussions Kohler 1-piece toilet flush valve seal replacement Dec 28, 2009
Toilet Forum discussions Kohler Flush Valve Giveaway Feb 26, 2017
Toilet Forum discussions Kohler Leaks & Seeps-Newest 1.28 GPF DISASTER! Feb 24, 2017
Toilet Forum discussions Kohler Wellworth Cannister - Water won't fill tank (seal is new) Feb 20, 2017
Toilet Forum discussions Kohler Highline Concealed Trapway Thoughts? Feb 16, 2017
