Knocking Hot Water Pipes
Discussion in 'Shower & Bathtub Forum & Blog' started by johnsonkar, Nov 28, 2004.
  1. johnsonkar
    johnsonkar New Member
    Nov 28, 2004
    Recently our hot water pipe started knocking when the hot water is turned off. This happens in both bathrooms located on the second floor of our house. What is causing this? What is the solution to stopping it? I found out that if I turn on cold water and then turn off the hot water, it doesn't knock. But try getting two teenage daughters to do the same. At any rate, I figured this was a plumbing problem. Our house is 16 years old--we bought it this summer.
  2. jadnashua
    Does this happen from any hot water faucet in the house, or only at one of them?
  4. mrdasu
    mrdasu New Member
    Dec 7, 2004
    I have the same problem and the noise is very loud, like someone is using a drill or hammer noise.
    this only happens when we turn on hot water in bathroom on the second floor ONLY.
    thanks
  5. jadnashua
    From what I've read here, a loose washer or valve seat can cause this.
  6. johnsonkar
    Nov 28, 2004
    Knocking Pipes
    Knocking pipes in the upstairs...pipes knock when the faucets are turned off AND when the sprinkler system is going...
    Driving me nuts...particularly since my sprinkler comes on at 4:30 a.m. and the noise in the pipes awakens me
    :confused:
Similar Threads: Knocking Water
Shower & Bathtub Forum & Blog knocking and shut offs... May 24, 2006
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Wednesday at 5:54 PM
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Tuesday at 6:47 AM
Shower & Bathtub Forum & Blog Faucet wall tubes and wall tube escutcheon is not water tight Feb 9, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
