KitchenAid gas stove model#KGRS807SSS
Discussion in 'Electrical Forum discussion & Blog' started by Mohsin67, Aug 31, 2012.
  1. Mohsin67
    Mohsin67 New Member
    Aug 31, 2012
    Milton, Ontario
    Hi my gas stove is having problems, the front 2 burners won't lite also the oven and broiler won't lite, I can lite the burners with a match so the gas I don't think is the problem. When I lite the oven I hear it click and the gas come on for a few seconds then off again, usually you would hear the oven lite up in these few seconds, what part do you think I need?? And where should I look for it??
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    North Carolina
    What you need is an appliance repair person.
  4. jadnashua
    Sounds like the ignitor/flame sensor is defunct in the oven...the ignitor(s) on the stovetop may be bad. Could be wiring, could be the devices, could be the switch/valve.
    Once the system sends a spark, it senses if the burner is actually lit. If it isn't, it (sometimes) tries again. Why it didn't light could be the gas actually didn't turn on, or the spark was weak or non-existent.
    WOrking with gas can be dangerous, so to keep from blowing up the house, it's best to have someone that works on them fix it.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Screw up with plumbing and you may have a leak or a drain that doesn't work well. Screw up with gas and you, you family, and you home are history. Get a licensed gas appliance repairman. Not everything is a DIY job, and this is one of them.
Similar Threads: KitchenAid stove
Electrical Forum discussion & Blog Adding Ground Wire to Kitchen Stove Jan 19, 2015
Electrical Forum discussion & Blog 50 amp stove line question Sep 9, 2013
Electrical Forum discussion & Blog Stove Wire Repair Mar 6, 2011
Electrical Forum discussion & Blog Stove/Range circuit Aug 5, 2010
Electrical Forum discussion & Blog Stove Hood feed.... Apr 21, 2010
