Kitchen Sink Sprayer Hose Leak
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kelsoz, Oct 26, 2010.
  1. kelsoz
    kelsoz New Member
    Oct 26, 2010
    PA
    Hi - I'm just average Joe Homeowner with a pinhole leak in my kitchen sink sprayer hose. Access to end fitting at the faucet assembly seems impossible with other tubes, etc. in close proximity (and, of course, high and rearward and behind sink back wall) Here are my choices in my order of preference:
    1: Remove and replace hose - Best, but how? Even a standard basin wrench seems unworkable.
    2: Repair hose in place. The location of the pin hole is near the faucet so it doesn't need to flex or pass through the sink hole. Is there a product that will do this for me?
    3: Remove sink (and hard-wired disposer) for easy access.
    4: Call a plumber.
    Are there other choices?
    Can you give me insight for 1 and 2?
    Thanks.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    if the hole is in the hose itself then there is only the remove and replace the hose option...
    Its pretty unusual to see a hose with a hole in it most of the time the sprayer is leaking. Are you sure of where the leak is?
  4. kelsoz
    kelsoz New Member
    Oct 26, 2010
    PA
    Hi Redwood - Yes, with foucet open, this hose gets pressure and shoots out a small diamerter - high velocity stream from a single location along the hose. When faucet is closed, stream continures but dies down as pressure decays.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    in that case you need to replace it.
  6. kelsoz
    kelsoz New Member
    Oct 26, 2010
    PA
    OK - So that nix's option 2. Any thoughts on others. I'm trying to get a stubby open end in there now.
  7. 6t7gto
    6t7gto DIY Junior Member
    Jan 20, 2010
    Bedford, Ohio
  8. hj
    1. There is a special "right angle" wrench for use with spray hoses.
    2. NO!
    3. You've got to be kidding, right?
    4. Best option, because he will have the necessary tools.
  9. kelsoz
    kelsoz New Member
    Oct 26, 2010
    PA
    Thanks all - finally got it loose with the basin wrench - seemed risky as I had to bend a little metal somewhere - but worked out. All back together. Thanks especially to 6t7gto - Had I seen that early on I'm sure I would have tried that and think it woulod have worked.
  10. hj
    It would have worked, but would have been rather expensive to have to buy a whole set just to get the one you needed.
Similar Threads: Kitchen Sink
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Sunday at 11:21 AM
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Sunday at 6:24 AM
Plumbing Forum, Professional & DIY Advice Kitchen sink still leaks Feb 15, 2017
Plumbing Forum, Professional & DIY Advice New kitchen, new sink, drain too high! Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink smell from non-disposer side Feb 12, 2017
