Kitchen Sink Shutoff Valves
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by psjr56, Jan 17, 2012.
  1. psjr56
    psjr56 Member
    Apr 23, 2009
    S. Jersey
    What is your preferred type of shut off valve for under a kitchen sink. Have to help my future son-in-law put in a new faucet and the cold shut off is seized. I usually go to the local Plumbing supply, stuff at the big box stores looks cheap. Doesn't have to be pretty. We'll also probably use SS braided hoses, cabinet has a center stile so getting in there is a pain. Thought about compression fittings, copper pipe is 1/2". Any suggestion or comments good or bad are welcomed, I have thick skin, lol.
    thanks, Pete
  2. Terry
    Aug 17, 2004
    I don't know if it's a code thing in Jersey, but on the West Coast, we use compression stops.
  4. psjr56
    psjr56 Member
    Apr 23, 2009
    S. Jersey
    Terry, What are compression stops? Is this the type of valve (e.g. ball valve) or the fittings to connect with. Never heard the term compression stop.
  5. jadnashua
    It's the manner in which the fitting attaches to the pipe. There are many, but some only work with certain pipes. On copper, your common choices in probable order of common usage are compression, soldered, or threaded. There are some companies that also make 'push-on' fittings that use gripper teeth and an o-ring(s) to make the seal, but the other three have stood the test of time.
    A compression fitting uses a compression washer over the pipe that gets sandwiched into the valve by a nut to make the seal. the soldered is probably obvious, as is the threaded one (where the pipe dope and/or thread sealant fills the gaps in the threads to seal). My preference is a 1/4-turn valve which doesn't have a washer to get old and stiff.
  6. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    Flare is not very popular in New England? Very common here in Florida.
  7. psjr56
    psjr56 Member
    Apr 23, 2009
    S. Jersey
    thanks for the replies so far. I was thinking 1/4 turn with compression fittings. Only place I've seen flare fittings used was either oil heater fuel line or on car fuel & brake lines.
  8. jadnashua
    As I understand it, flare requires soft copper...the more prevelant piping here is rigid copper.
  9. hj
    You would be most likely to find flare valves in mobile homes. Some new faucets, but maybe not Moen, come with integral supply lines these days, so you cannot use the stainless steel ones.
Similar Threads: Kitchen Sink
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink still leaks Feb 15, 2017
Plumbing Forum, Professional & DIY Advice New kitchen, new sink, drain too high! Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink smell from non-disposer side Feb 12, 2017
