kitchen sink installation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by wardair, Dec 27, 2005.
  1. wardair
    wardair New Member
    Dec 27, 2005
    purchased acri-tec drop in sink... instructions say run bead of chaulk under lip and drop into place.
    installed sink and 16hrs later the sink lifted right out
    there are no clmps listed or included is there a kit i can get to install the i gues self rimming sink
    they can be seen at acritec.com this isnt spam i just want to get the darn sink installed
    would plumbers putty do a better job
    also strainer basket rubber gasket under lip on top inside of sink or under sink
    cheers
  2. hj
    sink
    You did not use an adhesive caulk. Putty of any kind is not adhesive so the sink would still come loose. Use the plumber's putty between the drain and the sink with the rubber gasket on the bottom, unless there are two rubber gaskets in which case the thin one goes on top.
  4. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
    use phenoseal caulk (non yellowing adhesive) then put weight in the sink. clean excess with damp sponge.
  5. wardair
    wardair New Member
    Dec 27, 2005
    thanks
    i give it a try
    i was using tub and tile chaulk thats what the guy told me at the store
Similar Threads: kitchen sink
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Sunday at 11:21 AM
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Sunday at 6:24 AM
Plumbing Forum, Professional & DIY Advice Kitchen sink still leaks Feb 15, 2017
Plumbing Forum, Professional & DIY Advice New kitchen, new sink, drain too high! Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink smell from non-disposer side Feb 12, 2017
