Kitchen: Photoelectric Smoke or Heat Alarm
Discussion in 'Electrical Forum discussion & Blog' started by bjferri, Jul 18, 2007.
  1. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Department of the Army Civilian (DAC)
    Maryland
    Can I get some feedback on this?
    Everything I read states to not put a smoke alarm in the kitchen (false alarms), but if you're going to have one make it the Photoelectric type...then I read something about using the Heat alarm for the kitchen. Now I'm baffled...
  2. jadnashua
    Smoke detectors come in two flavors: ionization and optical. One looks for the ions created by a hot fire; the other looks for smoke from fires. The optical ones work faster on a smoldering fire, the ionization ones work faster on hot fires that give off ions. Either fire type will eventually set off. A heat detector goes off if the heat exceeds the set point, sort of like a thermostat.
    Cooking in the kitchen often produces smoke, so that type of detector should be avoided in the kitchen.
  4. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    My house is wired for both, the heat detector is wired through the alarm. The heat detector is set to read a certain temperature rise before going off, not a specific temperature.
  5. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    "Cooking in the kitchen often produces smoke, so that type of detector should be avoided in the kitchen."
    When you say that type, which type are you referring to? Also, when you say "optical" are you referring to Photoelectric?
    Are you suggesting a heat detector?
    Thanks
  6. PEW
    PEW DIY Senior Member
    When installing alarm systems we would never place a smoke detector in the kitchen, and always used a photo at the closest one to the kitchen. Keeping the closest as far as possible from the kitchen. One thing you do not want, especially if the system is being monitored, is false alarms from kitchen smoke. If you want fire detection in the kitchen use a rate of rise thermal detector.
    Yes, optical and photo are the same.
  7. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    Got it. Thanks!
Similar Threads: Kitchen Photoelectric
Electrical Forum discussion & Blog Question on 3-wire Kitchen Range > 4 wire Nov 24, 2016
Electrical Forum discussion & Blog Dedicated circuit kitchen rule for wet bar? Jul 4, 2016
Electrical Forum discussion & Blog Kitchen in basement - two circuits May 9, 2016
Electrical Forum discussion & Blog Kitchen Island install Dec 28, 2015
Electrical Forum discussion & Blog Updating Kitchen wiring in a 60 year old house Jul 10, 2015
