Kitchen p-trap/sink/pipe/drain predicament
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by in need of help, Nov 4, 2013.
  1. in need of help
    in need of help New Member
    Nov 4, 2013
    Alberta
    This was done by a certified plumber. A home inspector advised me that i have no p-trap. Went back to the plumber and he reassured me that he created one and due to the distance this was the best he could do. I accepted it not knowing better. Recently sewee gasses have been backing up into the home so called the city inspector and they advised me i need a p-trap amongst other things. I have done my research but am not 100% sure on what to purchase or hot to properly assemble the pipes to have a proper p-trap installed. I feel the sink drain is too low for the wall drain. Not sure how to get a p-trap in there. I have attached a picture. Any suggestions? 20131022_171732.jpg
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    You have a trap just not a p trap! Not was not installed by a plumber just a handihack! You have to start back at the wall where that copper pipe comes from
    and lower the drain in the wall and the bring it back under the cabinet with a real
    p trap!
  4. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    Your plumber is certified? by whom?
    Anyway, the wall drain is too high - lower it and install a P trap.
  5. Caduceus
    Caduceus Master Plumber
    Oct 16, 2013
    Just a Plumber
    Pittsburgh, PA
    The basket strainers are a bit deep and by having a more shallow type strainer installed could get you more elevation for the p-traps and drainage piping. But it is definitely true that that is not a p-trap. Some certified plumbers will do shoddy work to save time and money.
    The way I would do it is to cut open the wall and lower the drain. A p-trap could then be installed on each of the sink bowls. If the venting of the traps is an issue, each trap could be equipped with it's own approved auto vent. It also looks like there is a dishwasher discharge connection on the drain that is not connected or plugged off. If the wall cannot be cut open, then by using the shallow basket strainers that I mentioned and the auto vents for each trap, you could still have the proper installation.
    Of course we don't really expect you to do the work since you already paid a plumber to do it, but maybe printing a copy of this thread and showing the plumber it will remind him of how things should be done.
    Don't give up on this problem, plumbing inspectors are there to look out for your health and safety and keep tabs on poor plumbing practice.
    [​IMG]
    Short
    [​IMG]
    Long
  6. hj
    The "design" of a drain determines whether you have a "P" trap or not, and since yours IS a "P", you do have a P trap, but it is an assembled one, not a premade design. Your drain is a candidate for a two trap installation, because there is no way to connect the two drains together and still be above the wall pipe.
  7. in need of help
    Nov 4, 2013
    Alberta
    Thank you all for ur remarks and suggestions. They guy who did the nstall is licenaed and worka for Always Plumbing. I wont discredit the company because of one plumbers make shift p-trap. I will see about lowerirthe drain and putting in a manufactured p-trap. Thanks again!
  8. hj
    Did you see what I said about TWO "P" TRAPS, so you would not have to go to the expense of lowering the drain line, if it were even possible in your situation.
  9. hboogz
    hboogz Member
    Mar 12, 2013
    New York
    hj -- trying to shore up my knowledge. In the event that a drain is that high, it's always best to install a P-trap for each sink and, if possible, use shorter strainer's ?
  10. Terry
    Aug 17, 2004
    What he is saying here, You're boxed in a corner and this may be your only option.
    If the drain in the wall is vertical, you can cut in the tee lower.
    If it's horizontal, you may have to pull cabinets out until you find that vertical piece.
    Or..........you can arm over from where it is now, wye off for the second trap and get it done as best you can.
    Right now, most of the mess that is under there is under water, all the time.
  11. hboogz
    hboogz Member
    Mar 12, 2013
    New York
    Thanks for the info.
Similar Threads: Kitchen p-trap/sink/pipe/drain
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question 39 minutes ago
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Sunday at 11:21 AM
Plumbing Forum, Professional & DIY Advice Run natural gas to kitchen island - details Sunday at 7:06 AM
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Sunday at 6:24 AM
Plumbing Forum, Professional & DIY Advice Kitchen sink still leaks Wednesday at 8:52 AM
