kitchen faucet strange problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dodcar, Nov 4, 2007.
  1. dodcar
    dodcar New Member
    Nov 4, 2007
    Hello I am having a strange problem with my kitchen faucet.
    It is a kohler single handle with the little hand spayer off to the side.
    When I turn the faucet on there is always a noise that I describe as a boom. It isn't lound as in a sonic boom but it is noticeable. It sounds pressure related but I am only a homeowner so I don't know what is causing the noise. Also when I use the hand sprayer the water pressure is very low and then when I finish with the sprayer and try to use the faucet no water comes out of either the hot side or the cold side. I had to keep playing with the faucet, off/on to get it to work again.
    I installed the faucet about 2 years ago and these problems have only been a recent development. Any ideas on what the noise is when I first turn on the faucet and why the spayer pressure is so bad and causes the faucet to not work?
    Thanks
  2. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    the spray diverter is messed up and need to be changed. I would look into getting the parts under warranty
  4. dodcar
    dodcar New Member
    Nov 4, 2007
    do those things ever work? I don't think I ever had one that worked for any long period of time, either the pressure was weak or the hose never seemed long enough. Anyone like those new faucets where the sprayer is part of the faucet and you just pull it off the faucet to use?
    any better than others? If they are better than the old little sprayers maybe I will just get a new faucet.
    thanks
    cj
Similar Threads: kitchen faucet
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Feb 21, 2017
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Plumbers: Which kitchen faucet brands are tops in quality/reliability? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet removal. Can't get nut off. Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet ID Jan 26, 2017
