Kitchen faucet replacement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jerpop, Nov 14, 2011.
  1. Jerpop
    Jerpop New Member
    Nov 14, 2011
    Tennessee
    I recently replaced the complete kitchen faucet assy. with a similar unit. Very easy job, but, when turning on the hot or cold water, there is a slight knock(if you will) in the lines. I'm wondering if this is due to possible air in the lines some how. If so, how do I fix this? Note: This was not a problem with the old unit.
    Thank you,
    Jerpop
  2. jimbo
    jimbo Plumber
    Any air in the line is removed within seconds the first time you turn it on. Check to see that the shut-offs at the wall are fully open, and possibly you may have a loose washer in one of the shut-offs.
  4. jadnashua
    Does the unit have a sprayer? If the diverter isn't working properly, when pressure is applied by opening the faucet, it can slam closed. Look underneath the sink when turning it on and see if the hose to the sprayer jumps.
  5. Jerpop
    Jerpop New Member
    Nov 14, 2011
    Tennessee
    Yes, the new unit has a sprayer and I noticed it does jump a tiny bit when cold or hot water is turned on. The new unit attaches to the diverter by snapping it on rather than with a nut.
  6. jadnashua
    It sounds like the valve on the sprayer may allow a little water out when the main valve is off. Then, when you open the faucet, when it represurizes that line, it slams the valve shut. Call the manufacturer, explain what you've got, and maybe they can help...or, you live with it.
Similar Threads: Kitchen faucet
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Plumbers: Which kitchen faucet brands are tops in quality/reliability? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet removal. Can't get nut off. Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet ID Jan 26, 2017
Plumbing Forum, Professional & DIY Advice Hissing sound through pipes when turning on kitchen faucet Jan 11, 2017
