Kitchen faucet nut won't budge for removal
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by learning, Aug 2, 2010.
  1. learning
    learning New Member
    Aug 2, 2010
    MD
    I'm having an impossible time removing a 16-year-old Moen M7800 kitchen faucet. It's to be completely replaced, so it doesn't matter if it gets damaged in the process.
    Here's the main problem: rather than there being three lines (hot, cold, spray) that run through the central hole in the sink, there is a one central copper threaded line, with copper pipe extensions for all three connections soldered to the base of that.
    So there is only one rather large fixture attaching it to the underside of the sink, with a single metal washer and nut. The nut is about 1 3/8 - 1.5 inches diameter, and due to it's size, a basin wrench won't go around it. Due to it's age, it's corroded. It's in behind the center of a double sink, and hard to get a good grip with enough force with anything large enough to go around the nut.
    My local big box hardware store suggested spraying it with PB Blaster and giving it a go, even whacking it with a hammer to loosen it. I've done all that, but with no luck so far.
    I posted a full-size high resolution photo here: http://www.freeimagehosting.net/uploads/e8a57ce883.jpg so you can see what I'm up against.
    Oh, the garbage disposal is out, so there is a bit more room to move around under there. It's being replaced too, so it's gone so I could get at the faucet.
    If I could just get this nut off, I could be on with the rest of the project! Has anyone else run into this? Thank you for any advice and suggestions.
  2. jadnashua
    That doesn't look that corroded. There are basin wrenches, and then there are basin wrenches.
  4. jay_wat
    jay_wat Plumber
    Nov 9, 2009
    Skagit Valley
    get the proper sized drill bit,,that will make quick work of it! good luck to ya!!
  5. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    You need a ridgid # 1017 basin wrench that will take it right off !
    They are made much heavy-er duty then the cheap you might buy at a hardware store
  6. jimbo
    jimbo Plumber
    The neat way is to cut the nut with a dremel. I like to use a cold chisel. The nut will either turn, or split. It takes some "touch" because you don't want to damage the sink. I have done it often, with no accidents.
  7. learning
    learning New Member
    Aug 2, 2010
    MD
    Comforting to hear someone more experienced refer to it as not that corroded. (Pic was taken after 2 applications of PB Blaster, which did help some.) Excellent point about the basin wrenches. The ones I've seen around here (so far) are the smaller ones meant for water line connections, so I'll have to keep looking.
  8. learning
    learning New Member
    Aug 2, 2010
    MD
    @jay_wat: if only I had one that size…
    @MACPLUMB 777: Thank you so much for pointing me in the right direction for what to look for. Very helpful, as the ones I keep finding are pretty "cheap" feeling.
    @jimbo: I tried something similar to the chisel method you describe, with a flat-head screwdriver and a hammer, which obviously doesn't have the heft and force of impact a good chisel does. Great idea with the dremel. I might be able to borrow one; will have to do some calling in the morning.
    Thanks, everyone, for sharing your expertise with me!
  9. jimbo
    jimbo Plumber
    I guess what was meant was "if you want to see corroded, you should have seen the monster over at Mrs. Smith's house!" Sort of plumber's wives tales!
  10. hj
    faucet
    Even if you get it "loose" you will have a problem unless you have someone to hold the top while you struggle with the nut. Use a drill bit and drill on both sides of the nut. It will then "fall off".
Similar Threads: Kitchen faucet
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Yesterday at 6:03 AM
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Plumbers: Which kitchen faucet brands are tops in quality/reliability? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet removal. Can't get nut off. Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet ID Jan 26, 2017
