kitchen exhaust vent question
Discussion in 'HVAC Heating & Cooling' started by astro46, Sep 29, 2013.
  1. astro46
    astro46 New Member
    Dec 7, 2005
    Chicago
    I know, this really isn't an hvac question, the only relationship may be the use of sheet metal. Nevertheless: I want to install an undercabinet microwave vent hood combo over kitchen range. the current range hood (no microwave) exhausts into cabinet above, 6" rd vent, 2 90's, into wall, about 10" right of center, and up to roof.
    the new microwave will require raising the cabinet about 6". I don't think that the current 6" rd 90's will fit any longer. Possibly, using 4" 90's may work. The other option is to have a custom plenum made so that exhaust hood goes up into plenum and plenum out into wall (6" duct to roof). two questions:
    1. would it be ok to use 4" out of the exhaust then into the existing 6" to roof?
    2. anything wrong with the plenum idea? better, worse, no difference, than using 4" duct (assuming 4" duct will accommodate the curves)?
    Thanks,
    Jeffrey
  2. jadnashua
    Each hood device has a section in the installation instructions that says what diameter duct it needs and the maximum 'effective' length. The effective length is different than the actual length because every time you change direction, it creates more restrictions, making the run appear longer. Without knowing the model and what size it is designed for, there's no way to know if what you want to do will provide proper ventilation. In general, smooth curves and large diameter is what is the most efficient.
  4. astro46
    astro46 New Member
    Dec 7, 2005
    Chicago
    Right. I am aware of these instructions. Keeping the venting at 6" would be ideal. Short of opening the wall, plus dealing with possible obstructions that precluded putting the vent in the center in original installation, I am working with what I have.
    Question remains: is substituting 2 4" 90's for the existing 2 6" 90's going to be the "end of the world", or would a plenum be so much better that it is worth the extra time and money it would take to implement it. And, is there some reason why a plenum is not advisable in a kitchen exhaust duct. I know that they are used in hvac systems.
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Don't forget to install the fire extinguisher.
    Good Luck.
  6. guy48065
    guy48065 Member
    Sep 26, 2013
    SE and north MI
    Increasing your post count?
  7. jadnashua
    Again, without knowing the max effective length of the duct THAT system can support, there's no way to know if the 4" section with those elbows would take it over the maximum length. In general, restricting the diameter and changing directions a few times is a very bad idea. Keep in mind that the filters aren't perfect, and those extra elbows just become great grease traps. A plenum, properly designed, is better if you can avoid the 4" and elbows.
  8. astro46
    astro46 New Member
    Dec 7, 2005
    Chicago
    Jim, the actual length of the run is ap. 7 ft. currently has 3 6" 90 deg elbows in the run. From what I remember of microwave installation charts this is well below the recommended max. I suspect that substituting 2 4" 90's for 2 of the 3 current 6" 90's would not have an extremely negative effect on the operation Though, if there is a good chance that reducing the diameter of 90's coming out of the exhaust converter would cause a grease trap , and having a plenum is acceptable, I may go that route. Or open the wall and cut 6" off the existing vertical and use the system as currently constructed; more work, but back in operation faster than waiting for a plenum to be made. (Simplest of all, though, would be using the smaller radius of 2, 4" 90's).
    btw: does going from 4" to 6" have a negative effect on air flow, or increase grease collection? I would think that the air flow would be happy getting to 6" duct on its way out.
  9. jadnashua
    The larger the pipe, the quieter it will be and the more cf/m airflow you'll get (which is good). Any place there is turbulence or a reverse slope is a potential collection point. Going from 4" to 6" won't hurt, but again, it all depends on the max effective length the system was designed for. Some are surprisingly short, some aren't, and elbows add up very quickly.
  10. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Not really, Just thinking Safety First. Is that wrong ?
    Depending on the way it is done grease can be a problem.
    The Microwave will also need to have the proper ventilation, without grease building up in it.
    Have Fun.
  11. astro46
    astro46 New Member
    Dec 7, 2005
    Chicago
    quiet and perhaps 4" causing noticeable decrease in air flow would be good reasons to see about opening the wall and shortening the vertical. so, if all goes well that will be the plan. otherwise I will look at using 4" elbows between the microwave and 6" vertical.
    thanks for the info.
    Jeffrey
Similar Threads: kitchen exhaust
HVAC Heating & Cooling Electric NG valve for outdoor kitchen Feb 28, 2015
HVAC Heating & Cooling Toe Kick Under Kitchen Counter Electric Heater Nov 1, 2014
HVAC Heating & Cooling Kitchen Remodel and Radiant Heat. Jun 20, 2008
HVAC Heating & Cooling Can a bathroom vent exhaust duct be TOO short? Jan 30, 2017
HVAC Heating & Cooling Bath exhaust fan location advice Aug 23, 2016
