Kitchen drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Lar-bear, Nov 1, 2012.
  1. Lar-bear
    Lar-bear New Member
    Nov 1, 2012
    Amherst, NY
    I just purchased house and i'm remodeling kitchen. The current kitchen sink drain is 24 inches from floor to top of 1 and 1/2 inch drain pipe. My sink is 9 and 1/2 inches deep and will be mounted under granite counter top on a sink cabinet 34 inches high. Will I be ok with just 1/2 inch difference. I will not be installing disposal.
  2. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    You will need to relocate the drain. More clearance is needed.
    Open the wall up now while you are doing the remodle.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    You need more room, and flexibility for future changes.
    I would shoot for 15-16" off the floor to leave room for a disposal.
  5. Terry
    Aug 17, 2004
    I think 15" to 16" is becoming the new standard too.
    Without the disposer, you might be able to do 19", but for those three inches, and for a future alternate universe decision, I would do 16" and call it good.
  6. hj
    You have 1 1/2" from the bottom of the sink, NOT from the bottom of the sind drain you will have to install in the sink. Even if you did have 1 1/2" unless you used a "low inlet trap" which are very unstable, the inlet would be above the pipe in the wall. NOTHING will work other than moving the drain line or getting a different sink.
Similar Threads: Kitchen drain
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Yesterday at 11:21 AM
Plumbing Forum, Professional & DIY Advice New kitchen, new sink, drain too high! Tuesday at 3:54 PM
Plumbing Forum, Professional & DIY Advice WASHER DRAIN TO KITCHEN SINK TRAP Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink drain blockage Jan 17, 2017
Plumbing Forum, Professional & DIY Advice Help with kitchen sink drain pipe Jan 16, 2017
