Kinetico Model Number?
Discussion in 'Water Softener Forum, problems, installation and r' started by Onamac, Jul 31, 2013.
  1. Onamac
    Onamac New Member
    Camano Island, WA
    WHAT MODEL NUMBER IS IT?: I recently purchased a twin-tank Kinetico water softener that I thought was a Model 60. It's not. The insides of the control head are essentially identical with a Model 60, except it does not have the two white check "balls". Instead, it uses two yellow check "pins" about 1" long and 1/8" in diameter. Based on dates molded into the plastic housings, it was made in 2003 - 10 years old. The tanks are black, not tan, like my 26-year-old Model 60 (which is still working). Thanks for helping.
  2. mialynette2003
    mialynette2003 Member
    720
    Ocala, Florida
    It may be a model 60. They changed from the check balls to the pins but it is still a K60. The size of the tanks and the configuration determines the model #.
  3. Onamac
    Onamac New Member
    Camano Island, WA
    Thanks! Turns out you are correct - asking an expert usually helps! I just now managed to decipher the label on the tank enough to make out that it is indeed a Model 60. The tanks are black, but exactly the same size as my much older Model 60 with the tan tanks (8" diameter, 40.25" tall without the head). I have a call in right now to Kinetico to see if the serial number I believe I was able to make out provides more specifics.
    Do you know if this particular Model 60 (pins instead of check balls) is as good as the older ones and worth refurbishing? That's where I think I am heading.
  4. mialynette2003
    720
    Ocala, Florida
    As far as I know it is. If needed, I have a manual and exploded view parts list I will be happy to share. Just send me an email and I will send it to you.
  5. Onamac
    Onamac New Member
    Camano Island, WA
    New here. How do I do that without sending it out to everyone?
  6. amateurplumber1
    amateurplumber1 Member
    134
    Here
    Click his name and select private message! Good luck! This forum has been unbelievably helpful to me so hopefully I can help a little.
Similar Threads: Kinetico Model
Water Softener Forum, problems, installation and r Kinetico Model 60 recharging more often and using more salt than it used to Yesterday at 7:51 AM
Water Softener Forum, problems, installation and r Kinetico Model 60 Salt taste in house water May 20, 2014
Water Softener Forum, problems, installation and r Kinetico Model 60 resin replacement Mar 21, 2014
Water Softener Forum, problems, installation and r Kinetico Model 60 Issue with Softness Nov 9, 2012
Water Softener Forum, problems, installation and r Kinetico Model 60 won't draw Sep 3, 2012
