Kinetico K-60 is discharging constantly.
Discussion in 'Water Softener Forum, Questions and Answers' started by TinaB, Mar 18, 2012.
  1. TinaB
    TinaB New Member
    Mar 18, 2012
    Baltimore
    Our Kinetico K60 is constantly discharging water (just a steady trickle). It is going through 40 lbs. of salt every few days. We have replaced the piston parts and the float assembly.
  2. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    How old is it? Tan or black tanks? Who is "we"? Did you disassemble it or did a local dealer? Did levels 2 and 3 separate? It could be a seal that is leaking through.
  4. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    The drain seals may be bad. You would have to take the unit apart in order to replace them. If you need a parts breakdown, e-mail me @ affordablewtr@aol.com and I'll send then to you.
  5. TinaB
    TinaB New Member
    Mar 18, 2012
    Baltimore
    The softener is old but not sure exactly how old. The tanks are tan. We means my husband. It wasn't regenerating on its own and he tore it apart and replaced some parts. It regenerates on its own now but there is a constant trickle and we are going through about 40 lbs of salt every 2 to 3 days. I am hoping he can fix it since it is a $150 service charge plus parts. My husband is extremely handy but the water trickle has him stumped. Thanks for all of your help.
  6. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    I wonder if you can take a sample of the dripping water and have it tested to see if it is hard or soft? That would help narrow the problem. Is it possible to do this?
    If it is hard, then you have a problem with the drain valve.
    If it is soft, there are any number of causes, some of which are relatively easy to fix.
    In the older units like yours, levels 2 and 3 were 'molded' together. If there is a small warp between the two, water will be short-cutting and seeping through or by-passing water ports. This would require this section to be replaced with separate levels (2 & 3).
    Is your household water pressure less than 20psi?
    Whatever you do, DON'T lubricate o-rings or seals with Vasoline or any other petroleum product.
Similar Threads: Kinetico K-60
Water Softener Forum, Questions and Answers Questions about installing a Kinetico K-60 Dec 1, 2013
Water Softener Forum, Questions and Answers Kinetico Mach Quad Tank Softener Jan 22, 2017
Water Softener Forum, Questions and Answers Kinetico Possible Issue Jan 1, 2017
Water Softener Forum, Questions and Answers Kinetico sulfur guard valve Dec 31, 2016
Water Softener Forum, Questions and Answers Kinetico hookup help needed Fishers Indiana Sep 10, 2016
