Kinetico 60
Discussion in 'Water Softener Forum, Questions and Answers' started by Billyg57, Aug 1, 2010.
  1. Billyg57
    Billyg57 New Member
    Aug 1, 2010
    Center control switch etc.brine rinse,backwash water leaking from setting screw.Is there a gasket,washer or o-ring that could be bad?
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    could be, our Kinetico guy does not post here anymore though and I have not had enough of them apart to be able to say.
  4. Skip Wolverton
    Skip Wolverton In the Trades
    Dec 27, 2009
    Owner of SWS Systems. I work on most water treatme
    Ocala, Fl
    The plunger you push (actuator) to start a regen does have a o ring. If you push down on the actuator a couple times, that sometimes seats the o ring and it will stop leaking. If not, place unit on bypass, relieve the pressure and remove the 8 screws holding the clear cap on. Once the cap is off the unit, push down on the actuator and it will pop out. The o ring may stay in the clear cap. You may find a o ring at your local hardware store or a hrydraulic repair business.
Similar Threads: Kinetico
Water Softener Forum, Questions and Answers Kinetico Mach Quad Tank Softener Jan 22, 2017
Water Softener Forum, Questions and Answers Kinetico Possible Issue Jan 1, 2017
Water Softener Forum, Questions and Answers Kinetico sulfur guard valve Dec 31, 2016
Water Softener Forum, Questions and Answers Kinetico hookup help needed Fishers Indiana Sep 10, 2016
Water Softener Forum, Questions and Answers Kinetico peroxide tube overflowing Aug 22, 2016
