Brian Bennett
- Messages
- 9
- Reaction score
- 0
- Points
- 1
So, I can't seem to get my unit to stop running to the drain. It only does it when the unit is cycling to the top indicator position. When it is cycling through, with the indicator moving clockwise to the bottom it will finish the cycle and stop running to the drain. However, when it cycles moving to the top position it will not stop running to the drain. Not alot, mind you, but enough to make a difference. I would say about ten gallons per hour. The tech has replaced pretty much everything inside the head to no avail and want to completely replace the head at this point.
Is this covered in the warranty? I believe it is supposed to be a ten year warranty and I am within that period. I can't seem to find what the warranty is supposed to cover. Does anyone know? Or, if anyone has an idea why it is doing this and can help us get it fixed without spending 900 bucks I would appreciate it.
Brian
Brian
