Kerdi Showers
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by prashster, Feb 27, 2006.
  1. prashster
    prashster New Member
    Dec 7, 2005
    I'm thinking of installing a Kerdi shower in the basement. Have heard only good things about it. Any caveats for a diy-er?
  2. jadnashua
    The best DIY'er resource is at www.johnbridge.com
    The guy who sponsers that website has a huge team of pros that answer questions. He has also written several books specific to that subject. Their "liberry" has a detailed instructions on conventional shower construction, and many of those instructions are good for the basics.
    I've used Kerdi a little, and would seriously consider it for a new shower of my own. Neat stuff. By putting a waterproof membrane just under the tile, the cbu (which isn't used in this) nor the deck mud ever gets wet so the shower dries out much faster. You can build all of the walls out of regular drywall. If your floor is the size of one of their preformed pans, you can use that, or make your own out of deck mud. Then cover it with the Kerdi membrane. Then tile.
Similar Threads: Kerdi Showers
Plumbing Forum, Professional & DIY Advice Noble TS vs Kerdi board Sep 11, 2016
Plumbing Forum, Professional & DIY Advice Shower Drain Troubles with kerdi drain Dec 12, 2013
Plumbing Forum, Professional & DIY Advice Un-stick PVC Joint that got a little primer in it? (Kerdi Drain) Feb 25, 2012
Plumbing Forum, Professional & DIY Advice Kerdi with Noble May 17, 2011
Plumbing Forum, Professional & DIY Advice Kerdi vs Provamat drain? Jul 7, 2010
