Kenmore Water Softener
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DarylF08, Mar 5, 2007.
  1. DarylF08
    DarylF08 Mec. Elect. Engineer
    Dec 6, 2005
    St. Louis Missouri
    I hooked up an older Kenmore water softener with a new bypass valve.
    Where the valve goes into the softener, it leaks. New orings when installed.
    What do I try to fix this?
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    If you didn't buy the O-rings specifically for this softener, this possibly is the reason it may be leaking. If not, check to see if the assembly isn't twisted by the pipe arrangement.
    Plastic is notorious for cracking so there's a good chance that bypass has a crack in it, causing the problem.
Similar Threads: Kenmore Water
Plumbing Forum, Professional & DIY Advice KENMORE 350 WATER SOFTENER Apr 21, 2016
Plumbing Forum, Professional & DIY Advice Kenmore in door water despenser Mar 3, 2013
Plumbing Forum, Professional & DIY Advice Kenmore Ultrasoft 200 water softener torubleshooting Apr 10, 2010
Plumbing Forum, Professional & DIY Advice Kenmore Delux Home Drinking Water System Apr 6, 2008
Plumbing Forum, Professional & DIY Advice Kenmore Water Softener Control Valve Mar 9, 2008
