Kenmore Water Heater Install
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by art_d, Dec 7, 2004.
  1. art_d
    art_d New Member
    Dec 7, 2004
    On my new kenmore power miser 12 there is a blue plastic tube all the way up into the cold water inlet, threaded portion. I'm assuming this is the dip tube. Is this suppose to be up that far? And, how do I thread my heat traps into the cold water inlet with that in the way?
    Thanks
  2. jadnashua
    Is it a hollow plug put there to keep crud out until it was installed?
  4. The Pipe Rat
    The Pipe Rat New Member
    Dec 6, 2004
    The dip tube should slide into the threads and still allow you enough room to install your "Heat trap" nipples.
  5. art_d
    art_d New Member
    Dec 7, 2004
    Can someone recommend someone that can install a gas direct vent water heater on the Eastside, Seattle area? I'm sick of working on this
Similar Threads: Kenmore Water
Plumbing Forum, Professional & DIY Advice KENMORE 350 WATER SOFTENER Apr 21, 2016
Plumbing Forum, Professional & DIY Advice Kenmore in door water despenser Mar 3, 2013
Plumbing Forum, Professional & DIY Advice Kenmore Ultrasoft 200 water softener torubleshooting Apr 10, 2010
Plumbing Forum, Professional & DIY Advice Kenmore Delux Home Drinking Water System Apr 6, 2008
Plumbing Forum, Professional & DIY Advice Kenmore Water Softener Control Valve Mar 9, 2008
