Kenmore Intellisoft 350 problems
Discussion in 'Water Softener Forum, Questions and Answers' started by Mimo, Aug 29, 2010.
  1. Mimo
    Mimo New Member
    Aug 29, 2010
    Arizona
    Folks,
    This was working fine up until a month or so ago. The low salt level indicator came on and the softner hasn't been working since.
    I refilled the unit with salt and tried to reset the low salt level and light. Doesn't allow me to. Just beeps. Tried to manually regenerate. Wont let me. Button doesn't do anything.
    I can change the other settings (regen time, hardness level, etc), but nothing else. I don't believe it's auto-regenerating either. The salt has remained at one level for a few weeks now.
    Any ideas?
  2. Skip Wolverton
    Skip Wolverton In the Trades
    Dec 27, 2009
    Owner of SWS Systems. I work on most water treatme
    Ocala, Fl
    Push and hold the regen button. Does it advance into a cycle? If not, push and hold the select button for 4 sec, then push and hold it again. This should put you into the secondary mode. There you can scroll to the screen with 3 000. Once there, push the regen button. Does the unit advance into a cycle?
  4. jimtum
    jimtum AAW
    Aug 27, 2010
    Water Treatment Specialist
    Decatur Tx
    Skip does that work on all Kenmores? And what else does it allow you to do?
  5. Mimo
    Mimo New Member
    Aug 29, 2010
    Arizona
    Got here, but does not advance to regen.
  6. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    So doing a regen now would NOT turn the motor? the Motor would not run?
    If you push regen now and the control face changes then that part is working but if the motor is not turning then I would say that the motor is gone.. cheap motors..
    If it is under a year you might be able to get it under warranty..
  7. Mimo
    Mimo New Member
    Aug 29, 2010
    Arizona
    The motor does not run. It's totally silent. Nothing happens.
  8. Akpsdvan
    Dec 29, 2009
    Alaska
    Have a 24 volt trans former around to try a jump on the motor?
    Or might you have some small jumpers to go from the in line of power to and go straight to the motor ?
    I am betting on the motor is shot...
  9. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    Yes. The Kenmore (Sears) softeners have a dianositic mode where you can check the micro switch and meter turbine. In this mode, you can puch the regen button and it will start immediately.
  10. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    If the motor does not run after pressing the regen button, the controller should come up with an error code 1 if in fact the controller shows in regen.
  11. jimtum
    jimtum AAW
    Aug 27, 2010
    Decatur Tx
    Thanks, do you have a book for this info and if so where can I get one?
  12. Mimo
    Mimo New Member
    Aug 29, 2010
    Arizona
    I'll take another look to see if I get the error code.
    Other than that, i do not have the equipment or know-how to perform a jump on the motor.
    Is there anyway, via diagnostic mode, to tell how many times this thing has regerated or cycled? It's practically brand new. Out of warranty but under utilized until about 4 months ago.
  13. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
  14. jimtum
    jimtum AAW
    Aug 27, 2010
    Decatur Tx
    Gracias skip
  15. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    These models do not show the amount of regen or days since install. You can buy a multi meter at Lowes or Home Depot for $11.00 +/-.
Similar Threads: Kenmore Intellisoft
Water Softener Forum, Questions and Answers Kenmore intellisoft 350 problem Jan 15, 2017
Water Softener Forum, Questions and Answers Kenmore control failure Feb 16, 2016
Water Softener Forum, Questions and Answers Sears Kenmore 370 at wits end :( Feb 14, 2016
Water Softener Forum, Questions and Answers Kenmore Ultrasoft 150 stuck in regen mode Jan 22, 2016
Water Softener Forum, Questions and Answers Kenmore water softener problem Jan 21, 2016
