Kenmore Fridge Ice Maker Not Freezing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by wneikrie, Dec 24, 2013.
  1. wneikrie
    wneikrie New Member
    Dec 24, 2013
    Denver, CO
    Hi! I have a Kenmore 795.78409.801 fridge and the ice maker has stopped freezing ice. Both the fridge and the freezer are maintaining proper temps, but the cold plate in the ice maker compartment is warm to the touch. I have no water flow issues... I turned off the ice maker all night and am now waiting to see if turning it back on has inspired it to start up again.
    Thanx!
  2. jadnashua
    Is it possibly stuck on the defrost/release ice mode? Do you have the manual that came with it? That often has a troubleshooting section in it. On some, once it has frozen the ice, it then warms the edge so it releases cleanly, then turns back off so it can make more ice.
  4. jm66208
    jm66208 Member
    Aug 17, 2011
    Kansas City
    I put ice makers in the same category as disposers. Just not a repairable item. Look by the serial number & see if you can see something that reads like: Icemaker kit: IM501. Google it & you should be able to find one for around $50. I've used both the oem replacement ($200) & the no name brands & don't see a difference in longevity. Takes about 10 minutes to install.
  5. hj
    The gear is probably stripped which stopped the cycle.
Similar Threads: Kenmore Fridge
Plumbing Forum, Professional & DIY Advice KENMORE 350 WATER SOFTENER Apr 21, 2016
Plumbing Forum, Professional & DIY Advice Kenmore dishwasher Jun 22, 2014
Plumbing Forum, Professional & DIY Advice Kenmore disposal problem Dec 16, 2013
Plumbing Forum, Professional & DIY Advice Kenmore in door water despenser Mar 3, 2013
Plumbing Forum, Professional & DIY Advice kenmore stackable washer 88732 Jan 10, 2011
