Discussion in 'Water Softener Forum, Questions and Answers' started by richr1, Oct 27, 2010.
  1. richr1
    richr1 New Member
    Oct 27, 2010
    At 1st the water smelled fishy and we are using peroxide in the system. After several attempts the water guy has the system cycling 3 times a day. The smell is gone but now it spits from time to time and sometimes it will spit out black looking water. Usually at that point I will find green particals in the aerators, some large and some tiny. I was told by Kenitico that after 5 years of use I need to change the mediate? in the system as it is used to remove the sulfar smell from these pellets and they have broken down and need replaced. Do you know if that stuff is green in color or have do you any idea what this green stuff could be. The black water could simply be very dark green as the toilets are starting to get a greenish stain. Very hard to clean. Any help would be great.
    Thanks, Richr1
  2. biermech
    biermech Previous member
    Sep 13, 2008
    Owner SWS Systems
    ocala, fl
    Unfortunatly this is not the site to get the answers. Try do it yourself dot com.
  4. Gary Slusser
    Is that due to you not being able to answer the question or do you have some ax to grind?
    richr1, please describe your equipment in detail, in the order it is installed, what make and model control valve and explain how the equipment is supposed to work as if you are describing it to someone that can't see it.
