KDF Application
Discussion in 'Water Softener Forum, Questions and Answers' started by themitch, Oct 23, 2012.
  1. themitch
    themitch New Member
    Oct 23, 2012
    Binghamton NY
    Hello,
    I am looking for more information on using KDF-85 on a sulfur containing well water. I would like to know how well this works in conjunction with a GAC filter to provide filtered drinking water.
    Thank You,
    Brian
  2. Gary Slusser
    Retired
    IMO the best choice would be chlorination followed by Centaur carbon. GAC is not a good choice for H2S.
    KDF requires very high flow rates to backwash it and most private well water systems, and the pumps used, can not do it correctly.
  4. ditttohead
    Jan 9, 2012
    Ontario California
    KDF85 works very well for H2S removal, but... it requires considerable backwash water to do this. Check out the links, these will have the exact specifications you need to determine if KDF85 is right for you. If you have the backwash water available, then it may be an excellent choice and will provide many years of service, with very little maintenance. It is also an expensive media, but since many customers can get away with just using a single backwash tank without any chemicals, contact tanks, etc, the price may not be so bad.
    http://www.kdfft.com/success_hydrogen.htm
    http://www.kdfft.com/images/kdf_POESheet.pdf
  5. themitch
    themitch New Member
    Oct 23, 2012
    Binghamton NY
    Due to the pump in the well, I have no where near enough power for a proper back-flush. That is why I am looking to set up a small system for a small point of use. This filter setup would be for a water tap on a sink. In addition to this, I like experimenting with things. What I am looking for is getting 2 10" cartridge filter housings, a refillable cartridge, and a 1 micron ceramic filter. What I would like to experiment with is using a combination of the KDF-85 and some sort of carbon in the refillable cartridge, then after have the ceramic filter. The ceramic filter to clean out the IRB and what ever precipitates there will be, such as the copper monosulfide and ferric hydroxide.
    Brian
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
