K-9132 Drain Assembly Install Question
Discussion in 'Shower & Bathtub Forum & Blog' started by mccutch2, Mar 24, 2005.
  1. mccutch2
    mccutch2 New Member
    Mar 24, 2005
    The Kohler K-9132 literature mentions sliding the drain pipe at least 1.25" into the bottom of the 9132 assembly - then, as I will do, slipping the internal gasket (coated with soapy solution) over the pipe. In this case, I'll be using ABS pipe.
    Is this then sealed with clear silicone from above (looking down into the assembly/gasket/pipe), or is there another method? I have not installed one of these before and am looking for a seal that will not leak (obviously!)
    Placing this into a K-1668 shower unit. I understand that the gap between must be sealed w/ silicone. Thank you for any advice!
  2. Clayton
    Clayton Plumber
    Sep 26, 2004
    Shower drain
    To fully seat the gasket into the drain assembly around the pipe is all that is required to form a seal. It is nice to fill any gap with silicone to help seal and also to prevent it from holding water, hair, and soap scum for bacteria and mold to thrive in. However, for a better sealing shower drain IMO, I prefer to use this type of drain that has a packing nut that tightens down on top of the gasket compressing it around the pipe and into the drain assembly.
    http://img.photobucket.com/albums/v260/Claytonsplumbing/HPIM0319.jpg
  4. mccutch2
    mccutch2 New Member
    Mar 24, 2005
    Clayton - thank you for the reply. What name brand is the drain assembly that you included in the link you posted that has the packing nut compressing from above?
  5. jimbo
    jimbo Plumber
    San Diego, CA
    Several manufacturers make this type; Oatey and Sioux Chief to name 2.
Similar Threads: K-9132 Drain
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Mar 22, 2017
Shower & Bathtub Forum & Blog Schluter Kerdi Drain Mar 22, 2017
Shower & Bathtub Forum & Blog Odd Shower Drain Rough In Mar 5, 2017
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Feb 25, 2017
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Feb 20, 2017
